#76 |
The slots seem to be closer to what the aftermarket fenders have, so that's my vote.
#77 | |
![]() The Honda fender is pretty tough. I think if I leave enough material between slots, the fender can absorb rock hits without fracturing. ![]() ![]() I'm going to aim for 3/4" inch clearance between the fender an oil cooler, as you suggested. ![]() Spud ![]()
#78 |
I think that the slots as you have them laid out would be good. How do you plan to trim the slots?
#79 |
That's my question too. Maybe a router?
For me the holes would be easier to make cleanly with a step drill.
Happy to serve. |
#80 | ||
![]() ![]() Quote:
![]() ![]() ![]() ![]() ![]() ![]() If I cut slots, I want to keep them about 3/16" wide, to maintain fender strength. I also want to space the slots about 5/16" apart, for the same reason. I would make the slots about the length of a Dremel cutoff wheel, to minimize labor, and to maintain the strength of the fender. Finally, I would stagger the slots in each row, also to maintain the strength of the fender. ![]() Spud ![]()
#81 |
I'm going to buy these Harbor Freight, step drills today.
![]() http://www.harborfreight.com/3-piece...lls-91616.html Once again, thanks for the superb tip, Brother Bill! ![]() Spud ![]()
#82 |
How do you guys like this pattern?
![]() I want an attractive pattern, that is not too difficult to manufacture. However, function is more important to me than form. ![]() Provides good air flow Cleans itself from mud Protects against rocks Maintains fender strength Looks as attractive as possible Spud ![]()
#83 | |
Happy to serve. |
#84 |
As far as the specif pattern goes you can't go wrong.
![]() No matter what you're going to run cooler than stock. You win no matter what. :wink: Personally I'd go with holes rather than slots. Faster, cleaner, easier. Personally I know I'd not cut a perfectly straight line with a Dremel, and my experiance shows that cutoff wheels don't do so well on plastic. The plastic overheats, melts, and makes a mess and 'clogs' the cutoff wheel in short order. :? I'd drill holes and go for a ride and declare victory. 8)
Happy to serve. |
#85 |
Here are two more ideas.
![]() ![]() ![]() After all, my bike is a Honda XRL. ![]() Spud ![]()
#86 | |
I agree with Doc on holes being easier. I've struggled with trimming plastic before, and that's why I asked what you used. I'll trim the new blue fender to suit the TS185, and I don't want to make a mess of it.
#87 |
My Dremel tool worked great when I trimmed 2 inches off the front of my XR650L's fender.
![]() In any event, drilling holes is certainly much easier, especially with the step drills. ![]() ![]() ![]() Do you think I should drill 3/16", or 1/4" holes? Spud ![]()
#88 |
Hey I just had an idea :idea: . Go figure. :roll:
Don't drill anything yet. Ride it with no holes and monitor the oil temp. Maybe INSULATE the cooler so you have a starting point to follow. Then un-insulate it and retest. Then drill some holes and retest. See if more holes helps. This should really amuse the OCD scientist/engineer inside ALL us Chinariders! ![]()
Happy to serve. |
#89 |
I would go with 1/4" holes after experimenting with the no holes test.
The holes will be easier to make. With the step drill you can start at 3/16" and then move to 1/4". If that is not enough move to the slots. Final resort would be the mesh I sent. I think you will be able to clean it enough with a stick if it plugs up.
#90 |
OK. If I space the fender 3/4" away from the oil cooler, the fender should not melt.
![]() I could duct tape a sleeve of cardboard around the oil cooler to establish baseline temperatures without the oil cooler. ![]() ![]() If necessary, I think I can clean the plugged, 1/4" holes by poking my ignition key through them. ![]() Spud ![]()
