#77 |
The mirrors are a little smaller that the stock mirrors but way better. They have a blue tint which blocks out the glare. And don't vibrate like stock mirrors. This is something venom will improve according to Moose.
#79 |
They sure are. They stick out a little further so you see a little better around you too.
#80 |
Jerry, does that air filter fit on the stock carb?
#81 |
The filter is 48mm and the stock carb is 44mm. It might squeeze down enough with the clamp.
#83 |
There's a load adjuster on the bottom of the shock. You'll need a set of spanner wrenches.
#84 |
Thanks Jerry. You really are a huge help. The bike takes some adjustments to get it where I want it to be, but for the price, I’m enjoying it!
Plus, I don’t know what to do with myself if I don’t have a project and something I need to buy on Amazon! |
#85 | |
#86 |
Yeah, I’ve been slow to change out that rear sprocket because I wanted to get the new air filter on and get it jetted a little better first. Next I’ll change the sprocket and then over the winter I will likely try my hand at head porting and also sanding it down a mm to raise compression.
#87 |
I forgot to post the matching crank case breather filter when I removed the air box.
I also cleaned her up real good after a weeks worth of limestone dust collected on her. She cleaned up real nice.
#88 |
I bought MY Chinese bike on a whim, lol! My buddy came over on his Grom-knockoff Venom something-or-other. When I found out it was street-legal, I HAD to have one! I ordered the X22 by accident. Thought I was ordering a 3/4-size Ninja-copy and was a little disappointed in its size, considering it only had a 125 to push it. I only had it a few weeks before it was stolen. After I got it back, it was SO ugly that it took weeks before I even wanted to start fixing it. I was HEARTBROKEN! I ALMOST threw it away, I was SO upset! Now, I plan on making this bike my training bike til I feel comfortable moving up to a bigger machine.
2018 Venom x22/125cc (Baodiao 125-11) Lifan 150cc w/TB V2 roller-rocker head, Mikuni vm26 carb, and FMF muffler Last edited by Psomniferum; 04-01-2020 at 07:57 PM. |
#89 |
Did you rejet after the filter? How much bigger of a jet, if so?
#90 |
110 main on the PE30 carb. I never installed the pod filter on the stock carb.
