08-01-2024, 01:33 PM | #76 |
According to tracking, it should be delivered tomorrow.
09-02-2024, 07:13 AM | #77 |
I need to do the same. For the life of me I can't locate exactly were it's located. That thing is annoying. Lol
09-03-2024, 12:17 PM | #78 |
That reverse alarm is under the seat on the left side,looks like a cdi that's on the tao Bull 200,if anybody gets one & can't stand half of the state knowing you are backing up,lol
My camera anymore doesn't take a good picture |
09-03-2024, 12:20 PM | #79 |
Congratulation,I like mine,I just couldn't go back to 2 wheel drive.Pulling a cart loaded down with what-ever,plus in 4-wheel drive it will go in the snow.
09-03-2024, 12:22 PM | #80 | |
09-03-2024, 12:25 PM | #81 |
These are the same as Massimo at Tractor supply
21515sc TRANSMISSION ASSY 4WD https://www.massimomotor.com/21515sc...h-Power-Clutch Their all made by Linhai |
09-03-2024, 12:27 PM | #82 |
Thanks, you don't know how much i appreciate it. lol Man that beeper is annoyingly loud.
09-03-2024, 12:29 PM | #83 |
21515sc Transmission Assy
$1,243.13 |
09-03-2024, 12:33 PM | #84 |
You could probably buy that transmission cheaper on Aliexpress but shipping cost is gonna be high though?
09-03-2024, 12:36 PM | #85 | |
I never thought about it but you might could wrap some black tape around it,I would like to have something other than the light to let you know your are in reverse so you don't jump on it & hit the gas & throw yourself over the handlebars,I've almost done it not knowing I was still in reverse. |
09-03-2024, 12:43 PM | #86 | |
09-03-2024, 12:47 PM | #87 |
They have another transmission that instead of SC after the number they have an SD after the 21515sd
the sc stands for speed sensor. Probably chipped a tooth inside transmission,you might could buy the individual gear??/ |
09-03-2024, 04:14 PM | #88 | |
download schematic first,it might not be as bad as you think,maybe drop the transmission These all use the same transmissions Might be like my starter clutch,just hung up Could it just maybe be the shift rod? |
09-03-2024, 04:30 PM | #89 |
I had another NGK plug go bad on me.I'm done with NGK,I went out and bought a Champion 4 pak of 809(RA6HC)
