05-28-2020, 01:10 PM | #76 | |
I do intend on some video. I had all intentions on shooting video this morning on my way to work but got sidetracked and forgot all about it until i was halfway to work. Rain will be back tomorrow but will clear up for the weekend. I have to paint the new hood for my wife's car and install it Saturday so maybe a Sunday shoot.
05-28-2020, 02:20 PM | #77 |
Inspired me to do a muffler swap. I like the look of what i ordered to be here this weekend but it also will open up the choke down to a 2 inch slip-on. I hope it looks good with the blue paint 😁. That being said I haven't upped the compression at all yet so hopefully it is an upgrade and not going to force my hand to make a move on the wiseco that you did or the Athena big bore kit. I'm leaning towards the big bore kit though 🤏
2018 Venom X22R 18/34 sprockets, NGK spark plug,reflective rim tape, phone mount/charger, CNC tag bracket,LED headlights, LED anti flicker, oil cooler, gutted cat, sai delete, titanium exhaust wrap, 115 main jet stock carb, pod filter and airbox delete, Kawasaki 400 stainless muffler. |
05-28-2020, 02:30 PM | #78 | |
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-29-2020 at 07:58 AM. |
06-01-2020, 08:42 AM | #79 |
Yesterday afternoon i did my weekly pre-ride check up and maintenance for my weekly commute. The usual stuff like lubing and checking the chain, checking bolts and so on. I decided to pull the plug and noticed i was running pretty lean. I went ahead and replace the 120 main with a 125. I can defiantly tell the difference on WOT this morning. It feels like shes running perfect but I'll check it again when i get home and see how the plug looks. Only problem i see is it looks like rain for the rest of the week.
06-01-2020, 12:10 PM | #80 | |
I think we are out of the woods here with rain for at least a week. About dang time too. This is one of the wettest springs I can ever remember.
06-01-2020, 12:29 PM | #81 |
I got a feeling that the 125 will probably be to small as well. I'll just keep bumping it up until i get it right. I have my A/F gauge ready to hook up and wire for the mig to weld in a bung. Just have to find the time to install it.
We have to keep a eye on the gulf for the next few days. Looks like we got some tropical weather heading our way.
06-02-2020, 08:04 AM | #82 |
Well this is a first for me on the X22R. On my way home from work yesterday i came to an intersection. From a rolling start i nailed it and pulled the front wheel off the ground. I'm like "no way"! First light i get to i tried it again and what do you know. I did it again. I'm getting more impressed with the new mods everyday. I took a chance today and took the bike to work. I got my rain suit packed just in case. lol
I didn't get to check the plug when i got home because i got side tracked by the wife. I had to fix a flat tire. So, i'll check it today when i get home to see if i can up the main jet some more.
06-02-2020, 01:57 PM | #83 |
Well i did it, I just ordered a 4* offset flywheel key. I'll have to get my carb dialed in pretty good before i install it though. On to the next stage of performance gain.
06-02-2020, 04:42 PM | #84 |
How much lighter are you thinking of going with? Do you plan on keeping the clutch stock?
Electrician & Electronics Tech 2014 Honda CB500XA 2016 CSC TT250 1976 Honda CJ360T 2022 Honda Navi |
06-02-2020, 04:48 PM | #85 | |
The offset key will advance the timing 4 degrees. The timing on these bikes are retarded for crappy fuel.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 06-03-2020 at 08:22 AM. |
06-05-2020, 10:46 PM | #86 | |
06-06-2020, 07:43 AM | #87 | |
i got a set of these (but in blue) one of these (again, Blue) and one of these( oh look... blue...LOL bet that was a shocker... ) |
06-08-2020, 08:00 AM | #88 |
Well i had to cancel the original offset key order. As of Friday it was not shipped. I contacted the seller and was told it would be two weeks before he could ship. So i found another supplier and will have it by this Friday. I know what i'll be doing on Saturday morning.
I'm sure i could of made my own key. Once i have this one in hand i'll probably make one for the Hawk. As far as the clutch on my bike, it's not stiff or hard to pull. But you can tell it has a stronger clutch grip than the Hawk. As Megadan stated the clutch arm on the Hawk is much longer than on the X22R. I'll have to look for a shorter arm for the Hawk. Clutch play on the X22R is not as critical as it is on the Hawk. I never had any issues with finding neutral on the X22R.
06-08-2020, 11:09 AM | #89 |
I am definitely curious about the offset crank key. After playing with a few CDI boxes, I would like to experiment with combining one of them with more base advance
06-08-2020, 11:28 AM | #90 |
I just hope it doesn't make it hard to start with the 11:1 CR. And on the Hawk i might be a little gun shy on kick starting. lol
