03-13-2022, 10:41 AM | #61 | |
Brawndo: The Swingarm Mutilator (tm). It's got horsepower. It's what dual sport riders crave. |
03-13-2022, 10:48 PM | #62 |
I might have to get me a Brozz swingarm before I stuff one in my HAWK frame! Ha, ha, ha... CG strong, ride Hard!
03-14-2022, 02:10 AM | #63 | |
Pilot: 33 Needle: clip in 2nd position from top Main: 135 Now it starts fine, idles fine, and no bog anywhere in any throttle range. In my case tank was the major problem, got it fabricated and then the radiators' shrouds would not cover the extra-long husky radiators so got them fabricated as well. |
03-14-2022, 02:15 AM | #64 |
The only regret I have is, I should have gone for Big Bore Kit when I was rebuilding the motor. I am not sure why I decided to go with the stock kit.
Now around 2000 miles on the build, I am thinking to do the big bore kit but confused on which one to choose. 82mm (283cc tried and tested by multiple riders here on CR) or the 84mm (298cc which may affect the clutch as well as well as require carb change and an extra fan on radiators) |
03-14-2022, 12:59 PM | #65 | |
Did you go the CRF250R route for the exhaust? I've been trying to figure out what year header will work with the NC250. |
03-15-2022, 01:36 AM | #66 | |
I had a full system for CRF 230 lying with me for a long time. It is a clone as well from Aliexpress, my fabricator spent like 30 min to adjust the header to make it work with NC 250 exhaust port. The muffler is a bit loud but is not restrictive at all which is my first preference. |
03-15-2022, 02:56 PM | #67 | |
03-20-2022, 12:42 PM | #68 |
I removed a majority of the "extra" wire in the lighting harness. Even isolating only the lighting, horn, switch, and power sources there is still a lot of wire.
Going to try to finish up the harness this week as it's finally warm enough to work in the garage again. |
03-20-2022, 03:55 PM | #69 |
From my experience the green single common earth wire that services the front cluster and back to the main ground is not heavy enough gauge and should be replaced.
I had my loom frizzle a number of times and attribute it to this single green thin strand of wire. I ended up replacing the main ground and 12v ignition feed with I think 15amp auto twin core. |
04-16-2022, 04:28 PM | #70 |
Lighting harness is complete. Ran through tests on everything this morning. It all works. Now I just have to wait until I get the frame back so I make sure my wire lengths are correct and tie the positive wire into the hot wire on the ignition.
Don't need the lights bleeding the battery dry when the bike is off. |
04-17-2022, 04:32 PM | #71 |
Bench tested the new speedometer today. It came with zero wiring information. Luckily some digging around the web got me in the right ballpark.
Happy that I got it to power on. Tested indicator lights, speed sensor, and the gear indicator. All checked out. Funny thing is I believe these are the speedometers they are now installing standard on the 2021 and up RXBs. |
04-17-2022, 07:39 PM | #72 | |
I'm pretty sure you're right. That looks suspiciously identical to the one that came on my bike. |
04-18-2022, 10:39 AM | #73 |
I have only one issue with it, on high RPMs, when the bike vibrates, the digits on speedo starts flashing. I am thinking to add some vibration dampers to the speedo mount. |
04-18-2022, 12:58 PM | #74 | |
I actually had that same thought when I was looking at the bracket last night. I will take your experience in stride and throw some rubber grommets in there to give it a little cushion. Any chance I could bug you for a picture of the "settings" page on your cluster (pulse, tire size, cylinders, etc)? I think I have mine setup correctly, but if yours working accurately...I'd love to steal your settings. lol |
06-10-2022, 01:27 PM | #75 |
Spoke with the fabricator on Tuesday. We talked at length about the amount of time it has taken him to get all the frame work done. I appreciate that he was honest about it (this type of project isn't what keeps him in business), but I still lament the fact I haven't had my bike since December.
I have been promised that I'll have everything back within the next week. I am not holding my breath, but I am hopeful. It means I will spend most of the summer running the wiring, testing the engine, and slowly re-assembling the bike. Fingers crossed, I have a meaningful update in the next few days. |
