Old 04-17-2022, 10:37 PM   #61
dr99miller   dr99miller is offline
Originally Posted by Falkon45 View Post
Nice. Those like a lot like the KPT200 exhausts.
I'm 99% sure you are correct.
2021 Lifan KPM 200
2019 Venom BD578Z E-Vader
Old 04-19-2022, 07:26 PM   #62
lifanpoweredstore   lifanpoweredstore is offline
Hey! I'm Mike, the guy who's producing these pipes.
You are correct in that these come from the same manufacturer that makes the KPT Pipes! That's how I found em I had them(HOTMoto Store on Alibaba) produce more optimized midpipe dimensions that fits a little better than the KPT's and had them rework the tolerances on the header bracket so it fits better..
I'm working on the whole washer-shimming thing still. It's stamped sheet metal so I don't have much control over thickness but hopefully I can get them to increase the collar length for better fitment
Old 05-31-2022, 11:32 PM   #63
Acqua512   Acqua512 is offline
Has anyone replaced the oilf filter cap yet? Was doing a oil change and was wondering what cap fits it
Old 06-01-2022, 08:29 AM   #64
Falkon45   Falkon45 is offline
Falkon45's Avatar
Filler or filter?
Why do you want to replace said piece? It's a rather overlooked part, unless you're planning on doing some motorsport that requires something to be safety wired.
So far, nothing has been looked for, as far as I know.
Old 06-05-2022, 07:39 AM   #65
Filler or filter?
When I went to do a oil change, one of the ears broke off the filter cap.
Old 06-05-2022, 08:12 AM   #66
Falkon45's Avatar
Ahhh. You can contact venom motorsports, and they can get the part for you. There's also a link on the first page to a place where you can find parts
Old 06-05-2022, 09:39 AM   #67
I tried those links and did end up contacting venom. Getting the cap from venom was cheaper but I also used the oil filter 24994 and the gasket seems like it's too thick.
Old 06-05-2022, 10:09 AM   #68
Falkon45's Avatar
On page 3, there's a list of all oil filters that fit.
The one you mentioned isn't on that list
Edit: I went to the actual cross reference, and saw it on the list. I'm sorry I got that wrong. Interesting that it seems bigger than the rest. I'm using the K&N filter, and didn't have any problems. The fram filter and the K&N are pretty much mirrors of the factory metal filter. Did you change the O-ring, also? I never changed the original o-ring. That may be the difference.
Last edited by Falkon45; 06-06-2022 at 08:36 AM. Reason: corrected myself, and added info.
Old 06-06-2022, 10:44 AM   #69
RobertSX4   RobertSX4 is offline
RobertSX4's Avatar
I got the WIX 24994 as well and changed the o-ring, I didn't break anything but the oring being too large sheered off and kind of smeared itself between the end of the filter housing and the recess its supposed to stay in so it started leaking, I put the original o ring back in and have been fine. The filter itself appears to be a proper size, just not the wix oring. It was also way harder to get on and did not "pop" into place like the original does
"It's all falling apart like a Chinese motorcycle" - Rodney Dangerfield as Larry Burns
1975 Honda CB750K
1975 Honda CL360
2020 Lifan KPM200
Old 06-06-2022, 12:44 PM   #70
Teklock   Teklock is offline
Originally Posted by Hari View Post
Has anyone found a wiring diagram? Doing a walk around today I noticed my rear brake pedal doesn't trigger the light and also the high beam switch doesn't work. The momentary finger switch works, but not the wide beam thumb switch.
There is a wiring diagram in this manual:
https://cdn.shopify.com/s/files/1/02...f?v=1639718102
Old 06-25-2022, 06:03 PM   #71
Falkon45's Avatar
https://photos.app.goo.gl/B1JkajBdXLVdUAk38
At 4300 miles now. Did a new chain and sprockets. Factory 16t front sprocket, and 45t rear sprocket I bought from Chinahao.com. It came with an o-ring chain that I did not decide to use. Instead, I used a Turner Performance regular 428 chain. (Gold, of course. Lol). Went ahead and did an oil change, greased the rear Axel, inspected the cush drive, and looked at my rear tire. I was gonna bleed the rear brake, so I could get better feel out of it, and adjust the valves, but I had to hurry and get to my nieces birthday party.
Anyway, at 4300 miles, the rear tire is doing okay. Straight roads out here have the rear tire pretty squared off. But, it's holding up well. It'll probably make it the typical 6k miles. I have the S20s on standby, and I can finally mount the tires myself.
Anyway, with the 45t sprocket, 1st and 2nd gear are far more usable. I can still hit 60 by 4th gear, but it takes a lot longer to get there. 5th and 6th barely have power to maintain 60, and I drop to about 57-58.
If I was lighter than the nearly 260lbs that I am, I'm sure this bike could maintain 70 comfortably. I'll try and adjust the valves and check for power gains
Old 07-02-2022, 06:23 PM   #72
KPM   KPM is offline
Silly question. I'm still in assembly stages. In the bag of parts, there are 2 rubber strips and can act like zip ties. Where do they go ? I didn't see them mentioned in the few pages as the assembly manual, or the online assembly video.
And I'm assuming the steel gasket is just a spare exhaust manifold gasket, not that it was left out at the factory ?
Old 07-02-2022, 08:53 PM   #73
Falkon45's Avatar
One is for your battery, and one is for the non existent tool kit.
Old 07-04-2022, 02:57 AM   #74
TheLetterJ   TheLetterJ is offline
So whats the best oil for the KPM200? Link please
Old 07-04-2022, 08:21 AM   #75
Falkon45's Avatar
The oil is completely up to whatever your preference is. I use Castrol in all my vehicles, except my Yamaha.
