Old 05-09-2018, 11:52 PM   #61
pistolclass's Avatar
wait I just thought of something, are you picking your feet off the ground when you are riding?
Old 05-13-2018, 01:34 PM   #62
kyriakos   kyriakos is offline
Looks like we've find the issue..
https://photos.app.goo.gl/fJnUAyHYXCJU0U8R2
'17 Hawk / Mods: Mikuni 120/27.5, Airbox, .003 valve, 17f/45r, NGK Iridium, Aluminum Performance Exhaust
Old 05-13-2018, 01:46 PM   #63
Shrug   Shrug is offline
Shrug's Avatar
is that a horde symbol FOR THE HORDE
Old 05-13-2018, 02:06 PM   #64
That definitely a good start. Where is the air going though? Coming out a port, or the crankcase?
Old 05-13-2018, 07:31 PM   #65
franque   franque is offline
Yeah, I'm curious about that too... It shouldn't run at all with that much of a leak, unless one of the valves is open. Is that the lowest number that you get, when rotating the engine in the correct direction?
Old 05-14-2018, 09:10 AM   #66
blanc12   blanc12 is offline
Something is wrong with this leak down test If it has 150 psi in a compression test. A valve must be open or a leak in the line to the head maybe. Make sure it is on top dead center. It is just like adjusting the valves.
Old 05-14-2018, 12:37 PM   #67
Usually, what I do is slowly rotate the engine while cold at least two times with a breaker bar (since there's no ratcheting action), and whatever number is the lowest is your correct leakdown %. Then, you listen to where the air is escaping from, and then you have an idea of what is gone wrong. Just to double check, it's been verified that the clutch isn't slipping? Usually 10-12% is acceptable for leakage.
Old 05-20-2018, 05:09 PM   #68
Any updates?
