11-08-2017, 02:47 PM | #61 | |
I just ran across this, which isn't a super amazing deal price wise, it is a bit cheaper than normal. https://www.amazon.com/D-I-D-Pro-Str...rds=428+X+ring
11-08-2017, 10:27 PM | #62 | |
11-08-2017, 11:04 PM | #63 |
Well, I went and did the carb adjustment today. It was originally turned out only a half turn. I turned it out a total of 1.5 turns as recommended to see how it runs like that. I turned it on and warmed it up a little afterwards with the intent to ride it around for 10 min but I found out I was late to an appointment so will need to actually see if it helped or not tomorrow.
I did notice that the hose from air filter to carb was twisted and bent a little to fit to the carb. It was like the hose (which is formed) does not actually belong in that location, or was put in crooked and someone made it fit. I am wondering how much this restricts air flow. I will post pictures later. Anyone else experience this? |
11-09-2017, 12:22 AM | #64 |
Yep, a lot of those intake pipes come kinked like that. Some people simply put a hose clamp over the kinked area and tighten it until it opens up.
11-09-2017, 05:03 AM | #65 |
Does that plastic cap at the bottom of the carb need to be replaced? it was shoved all the way in and kind of got ate up on removal but I can try and replace it if needed.
11-09-2017, 05:06 AM | #66 |
Today I an looking at greasing the pivot/swing arm, anyone have any tips on how to do this? do I just remove the bolts,, throw some grease on them and replace?
11-09-2017, 05:06 AM | #67 |
No need to replace it. It was just a tamper proof cap.
11-09-2017, 05:13 AM | #68 |
Yes, thats pretty much all you need to do. I installed a grease zerk on my swing arm so all I have to do is pump it up with grease every once and a while.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-09-2017 at 07:54 AM. |
11-09-2017, 04:08 PM | #69 |
Gents, i need help. I am trying to do the valve lash but the space is not opening up. I have backed the screws out almost the entire way and i still cant even get .002 in there, much less the .003 or 4. I am at TDC i think. It is as the line immediately following the t. Both are still visible in the hole. What am i doing wrong?
11-09-2017, 04:16 PM | #70 |
Heres a picture of them.
11-09-2017, 04:18 PM | #71 |
Are they stuck? Can you grab onto the top "square" looking part with anything to get some extra leverage to turn them and open up the gap? I think it is around a 4mm if you can find a wrench that small
11-09-2017, 04:18 PM | #72 |
Here is another picture
11-09-2017, 04:20 PM | #73 |
They move, just the space doesn't open up and I'm worried they will be completly removed before it does.
11-09-2017, 04:23 PM | #74 |
Did you pull the spark plug and verify you are on the correct stroke?
11-09-2017, 04:28 PM | #75 |
I am on the mark directly after the T, they are both visible in the hole. I did not pull the plug, I put it in gear and pushed watching it rotate until the correct location then removed the head to see the valves.
