Old 10-09-2017, 11:19 AM   #61
This is where the problem is. That wheel shouldn't be behind the stopper plate.
2004 Honda ST 1300
Old 10-09-2017, 03:08 PM   #62
Andizzle   Andizzle is offline
Ok so I’m just going to use a flathead screwdriver and push it out from behind the stopper plate?
2014 Hawk 250
Old 10-09-2017, 03:13 PM   #63
Like this
File Type: jpg A6FCB38F-4FDB-4797-A205-B8B2F965946A.jpg (16.3 KB, 669 views)
2014 Hawk 250
Old 10-09-2017, 03:15 PM   #64
Originally Posted by Andizzle View Post
Like this
That's it. Hope it fixes you issue.
2004 Honda ST 1300
Old 10-09-2017, 04:00 PM   #65
and maybe if that fixes it take it back apart and put some loctite on the bolt cause if it loosened once it will probably do it again.
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 10-09-2017, 07:18 PM   #66
I tried pushing it out with the screwdriver but no luck. :/ I already got the shifting lever out though. I need to get a lock not remover and a gear holder so I can take the clutch off to get to it easier.
2014 Hawk 250
Old 10-09-2017, 08:31 PM   #67
its just jammed put more pressure!
2016 hawk
kaw h1 400 tripple
Old 10-09-2017, 08:33 PM   #68
check the stopper plate bolt after you get it out it may be bent.
2016 hawk
kaw h1 400 tripple
Old 10-10-2017, 10:10 PM   #69
https://imgur.com/gallery/z5dur
Here’s a link to pictures of the parts I took off.
2014 Hawk 250
Old 10-10-2017, 10:16 PM   #70
& a video of the stopper plate shifting into 1st and second. Should it be able to go all the way around counter clockwise or is it fine stopping where it does in the video? Sorry it’s kind of hard to tell in the video. And when I put it all back together do I want it to be done in Nuetral?
2014 Hawk 250
Old 10-10-2017, 11:13 PM   #71
im not sure but i dont think it matters. that pin will register with the hole in the stop plate. looks to me like your problem was just the stop plate being loose and the little wheel that rides on the outside of it got behind it and finally jammed.
2016 hawk
kaw h1 400 tripple
Old 10-11-2017, 07:35 AM   #72
Looking at the pictures all the parts look fine. It's really hard to tell from the video. But look like you got full rotation. You should be able to rotate it about 340-350*. Have you tried reinstalling all the parts and trying going through all the gears? If your getting full rotation of the stopper plate and it doesn't go through all the gears after that then it could possibly be a bent or broke shift fork. That would require to remove the engine and splitting block. When you drained the oil, was there any metal in the oil or oil screen? Before I would do that I would try putting it back together and see if it will shift through the gears. The pictures and videos do help.
2004 Honda ST 1300
Old 10-11-2017, 09:38 AM   #73
Does it matter if I put it back together in nuetral or 1st? Is it a just a matter of what’s easiest?
2014 Hawk 250
Old 10-11-2017, 09:41 AM   #74
Doesn't matter.
2004 Honda ST 1300
Old 10-11-2017, 10:21 AM   #75
Ariel Red Hunter's Avatar
Did you have your buddy rotate the rear wheel while you turned the shifting drum? The shifting forks operate in slots on the outside of the shifting drum, inside the transmission. I'd try that before I put it all back together...ARH
enduro, hawk 250
