04-20-2017, 12:54 PM | #61 |
That's a good looking bike. Have you ridden it on the highway much? Was just curious how it would do on paved top speed wise. I saw one video online that got up to 71MPH on pavement.
04-20-2017, 01:46 PM | #62 |
Haven't wanted to push it too hard yet!
After its broke in I will GPS the top speed. It's advertised as 74mph. I did hit 70 for a brief moment the other day. Taking it out this weekend for a good shakedown run.
1993 CR125 powered by Zongshen 223cc OHC 2̶0̶1̶6̶ ̶L̶X̶R̶ ̶2̶5̶0̶ ̶E̶F̶I̶ ̶ Sold 2018 GPX Moto FSE250R 1993 Fantic Key-Roo 250 |
04-20-2017, 03:18 PM | #63 | |
I can cruise at highway speed but it's still hummin' with that 13 the front. Came stock with a 14.
04-20-2017, 03:50 PM | #64 |
I look forward to seeing how it turns out, looks like the fit and finish is pretty top notch for such an inexpensive bike, not to mention a lot of upgrades! Could turn out to be quite the little enduro, especially if it has the same engine as the RX3.
04-20-2017, 04:12 PM | #65 | |
Not verified, but the PPro website says 13/49, as does the parts order manual.
04-20-2017, 09:21 PM | #66 |
Now with verification!
Decided to check the sprocket situation out as we have already seen that some of the specs on Pitster's page are off.
Turns out the front is a 13 tooth! BUT, rear is a 51;
04-20-2017, 09:27 PM | #67 |
While we're measuring stuff...
Pitster LXR250 front forks measure about 47mm ; tough to hold tablet, micrometer, get focus and push camera button all at once, so forgive the quality here:
The housing of the front forks just below the top triple clamp are 53mm :
04-20-2017, 09:40 PM | #68 |
Rear Spring Rate
Here is a picture of the rear spring rate. It says "FastAce 300lbs/in".
300 lb/in = 5.3 kg/mm A little light for my heft... looking at my old Honda and perusing Racetech on bikes with similar geometry I should be looking for a 6.0 kg/mm or 336 lb/in spring rate. In my experience getting the rear spring rate right makes more difference than all the tuning you can do on the wrong spring will ever make.
04-20-2017, 09:47 PM | #69 |
is that metal shavings on the frame under the shifter or just dirt?
04-20-2017, 10:06 PM | #70 |
Its dirt embedded in the chain grease/oil (very thick). Looks like the wear guard is chunking a little and some of it is the plastic bits. The picture makes it look metallic, but when I wiped it off it didn't have any metal in it. I do remember why I like o-ring chains...
04-20-2017, 10:11 PM | #72 |
Desert tank ordered.
Pulled the trigger on an oversized tank. 4 gallons is necessary for some of our longer trips... 5 gallons if we get lost. Which is the normal way things go down.
I'm hoping it will fit this bike; if it does I will post the part number and manufacturer. Right now I'm taking a chance.
1993 CR125 powered by Zongshen 223cc OHC 2̶0̶1̶6̶ ̶L̶X̶R̶ ̶2̶5̶0̶ ̶E̶F̶I̶ ̶ Sold 2018 GPX Moto FSE250R 1993 Fantic Key-Roo 250 Last edited by ChondaChondaChonda; 04-20-2017 at 10:13 PM. Reason: add info |
04-21-2017, 02:54 AM | #74 | |
Was the drain plug a wee bit on the tight side ? ..
04-21-2017, 08:21 AM | #75 |
Every bolt I have touched on this bike have been way too tight!
It was an effort to get that out- I used a Wera socket set, which is german made and the best sockets I own. Nearly pulled the bike over getting it out.
Tags |
efi, fuel injection, lxr250, pitster |
