Old 04-11-2017, 06:44 AM   #61
old kid   old kid is offline
old kid's Avatar
i did the same thing to my hawk before the plate even went on it. i installed two led lights above it to replace the plate light, and made a new bracket out of a piece of 1/8" aluminum plate.
Old 04-11-2017, 07:33 AM   #62
goat67   goat67 is offline
goat67's Avatar
Originally Posted by Kipper1012 View Post
LOL yea I saw your rusty mess.
Ive tried today to find a 1/8" inline filter locally and had no luck. Im going to try a 1/4 and replace the stock fuel line with a 1/4" line
I used a 3/16" inch line and I small engine inline filter sold in plastic packs at most parts stores.
Could not find clamps this size so used tie wraps
2016 Brozz
Old 04-11-2017, 10:19 AM   #63
MOTOXtreme   MOTOXtreme is offline
Utilizing 3-D Printed parts on the Brozz
Ive made brackets to hold this old Pelican case Ive never found a good use for until now. And 3-D printed a mount for the navigation too.
Brian
Previously owned / operated MOTO Xtreme selling American Lifan / Check out my friends at www.armattanquads.com
"Imagination is more important that knowledge" Albert Einstein
Old 04-11-2017, 10:44 AM   #64
Kipper1012   Kipper1012 is offline
Kipper1012's Avatar
Thats what I meant 3/16 LOL I was thinking of my model planes that take 1/8"
All everyone had was 1/4" filters but they did have 3/16 fuel line so I ordered the filters on line from amazon.
2016 Green Bashan Brozz.
Old 04-11-2017, 10:45 AM   #65
Kipper1012's Avatar
Very nice mount ! Looks secure
Old 04-11-2017, 10:50 AM   #66
Kipper1012's Avatar
Well this is what my fork oil looked like. It was 250ml so that's what i put back in. My engine oil looked the same way . However ............
My brake fluid was very dark and there was debris inside the reservoir . I cleaned it out very good and put good quality DOT 4 synthetic fluid took me 15min to bleed all the air out and swap the fluid.
Old 04-11-2017, 12:06 PM   #67
Ariel Red Hunter's Avatar
The oil (and maybe the brake fluid) is an anti-rust product to protect "The innards" of the bike until it gets to you. So, engine oil and fork oil, and if it was me, brake fluid should be changed very soon after the first start up, or even before....ARH
Old 04-11-2017, 12:15 PM   #68
Agreed and sure that's what kipper did. I think more emphasis should be placed on this. I've read many post where people say they "put the bike together one evening". Not enough time to do it properly in my opinion.
Brian
Old 04-11-2017, 02:53 PM   #69
Kipper1012's Avatar
Oh yes I've changed all the fluids engine oil , fork oil & brake fluid. Flushed the fuel tank out, set the valve clearances and installed a NGK plug. I'm also installing a inline fuel filter before i fire it up for the first time .
Old 04-11-2017, 02:56 PM   #70
Kipper1012's Avatar
I agree to proporly get thes bikes ready to ride I would say it could be done in a a day. With my work schedule I only work on it for about a hour after work so it's taking me longer :-(
Old 04-11-2017, 03:56 PM   #71
If anyone figures out how to keep the fuel gauge from going nuts at about 1/2 tank or lower let me know. I'm thinking a small capacitor would help?? I may have to try it.
Brian
Old 04-11-2017, 07:15 PM   #72
Musictrek   Musictrek is offline
Musictrek's Avatar
Check the resistance of the two wires coming off the float off the tank. The Res should be lower than 10ohms at one end with float postion maxed out and at least 95-97 ohms with the float position maxed out to the other. I think to get the cluster to read a full tank the resistance of the float needs to tell the cluster that its at 10ohms or less. Check the connection on the wire connector on the tank as well. I don't think a capacitor is going to do anything. The cluster works on resistance of the float. make sure the float in the tank is not getting hung up on the side of the tank as well.
Old 04-11-2017, 07:24 PM   #73
Musictrek's Avatar
I had the problem of the cluster never reading a full tank due to incorrect resistance of the float
http://www.chinariders.net/showthread.php?t=18626
Old 04-12-2017, 02:48 PM   #74
Kipper1012's Avatar
Lots of junk in my fuel tank.
I'm giving serious thought to costing the inside of the tank
Old 04-13-2017, 11:55 AM   #75
Kipper1012's Avatar
Well My MSR shifter just arrived and it wont fit
I ordered the one that fits the Hawk the DRZ-400 shifter
Manufacturer Part Number:070758
Hmmmmm
brozz, green
