#61 | |
#64 | |
That's a sharp bike, right there! Love the China Riders shout out. ![]()
#65 |
You are very welcome Sir!! Its the least I could do. This place is an invaluable resource. Some good folks that hang out here too.
#67 |
:Looks great! Very sharp!
Valves: on the CG motors, I run the intake at .05mm intake and .08MM exhaust. Ice cold, overnight. Never had an issue and get good time between adjustments. Tappy is happy. Since the exhaust valve gets hotter and takes more of a beating, hence the slightly wider gap to buy time between adjustments. These valves tighten as they wear. Can't wait to hear about your first trip! Congrats!
#68 |
Really looking good.
#69 | |
And thanks Guys, it really is a sharp lookin bike. And the more I play with it the more I'm blown away about how much you get for your money. I mean I see a few things they cut corners on, but overall they did a great job on this one. I've looked this thing over for quite sometime. Probably more than anyone should lol. Every single electrical connection was checked and greased with dielectric grease along with every nut and bolt. Also, I just got back from Columbia. I got a new spoke wrench, a cable luber, and a battery tender. And of course I went to harbor freight and got one of them rear axle lifts. This bike has a 49 tooth rear sprocket, not sure what the front one is. But I plan to change the chain when I do the sprockets. And you guys are so right, that factory oil looks liked pressed whale blubber or something. ![]() |
#70 |
Yes change the fork oil. There is a lot of info here on the howto part.
Bashan Blaze Mods: Alloy Rim's, Muffler, Mukuni VM26 Carb, Foam Filter, Tachometer, Volt Meter,LED Headlight, LED Blinkers Last edited by Merlin; 12-12-2016 at 07:56 PM. |
#71 |
Great video! Thanks for showing us where those mystery brackets go. I am not sure, but I think this is the first Chinabike I have seen that comes with those brackets. I don't see much difference between the 2014 and the new ones other than the USD forks on the 2016. We have not gotten in depth reports on the new ones, as the few members who have them seem to be in hibernation, so I wonder if they have the good carb, the NGK and Yuasa battery?
#72 |
I think that is same battery that came with my Hawk. I can't get to it to check it though. I replaced the battery with a tiny 1.5 pound Battery Tender.
http://www.ebay.com/itm/Battery-Tend...3D361647157846 It's also made in China and comes with foam blocks with for a tight fit
#73 |
Letsride, great work, I can tell your going to be a great resource contriburiter . The fender supports showed a greater commitment to quality parts and better design.
I liked the carbon fiber look too. Noticed that too back when they were introduced, makes it stand out a little. Culcune, your right this is the first look at a Brozz. ![]() Can't wait to hear and see the console digital speedo and tach. in action Also, look for a trunk, turns it into a great errand maker. (Six packs and lotto tickets ![]()
#74 | |
Nice, I didn't even know they made batteries. I love their trickle chargers though. I'll have to pick one of those up.
#75 | |
