02-22-2017, 01:47 PM | #61 |
Not sure why your thread didn't come up when I searched but it would have answered some needless posts I made, lol.
Question, just to be clear, in the end what did you convert your motor to? I believe you said it was a ZS169FMM which is 69mmx62.5mm - 232cc but you found a kit to make it 247cc? |
02-22-2017, 03:23 PM | #62 |
Crackerjac, My ZS169FMM is still stock internally.
It turns out that the 250cc cylinder I purchased has a larger bolt pattern than these 230 (223) cc clones. Won't work. My bike does have a new Honda Keihin carb and a Powr-roll exhaust header. Runs really, really well.
1993 CR125 powered by Zongshen 223cc OHC 2̶0̶1̶6̶ ̶L̶X̶R̶ ̶2̶5̶0̶ ̶E̶F̶I̶ ̶ Sold 2018 GPX Moto FSE250R 1993 Fantic Key-Roo 250 |
04-03-2018, 09:37 PM | #63 |
New update
Decided that I needed to give this bike some love. It's been neglected since I picked up the Pitster LXR 250.
Member Chadzu ordered this Otom stainless header for his 230 powered XR200, but decided it would not work and gave it to me. I had hoped it might fit the LXR, but not even close. With a little effort I was able to fit it up to this old Chonda; |
04-04-2018, 11:51 AM | #64 |
Did you have to bend it?
04-04-2018, 12:35 PM | #65 |
No, but the depth of the exhaust flange was wrong, so I had to make an extension about 1/2" long and weld it to the stainless pipe.
It exits at a little more "outward" angle, so I did weld a bend from the original tailpipe in to re-align it with the Supertrapp muffler. I'll grab a few more pics. This was a late night snap. I also mounted the original tank from my Pitster LXR250 on this bike along with the seat; it really changes the whole look and feel of the bike. Gives it a modern, sleek, low look that it was definitely missing with that old KX tank it had on it. |
04-04-2018, 09:03 PM | #66 |
Can you get some more pictures of the engine mounts? I'd love to do something like this!
04-04-2018, 09:47 PM | #68 | |
Front mounts made of thick aluminum Frame drop had to be notched to clear carburetor (XR200 carb and intake): |
04-04-2018, 09:53 PM | #70 |
Obviously there is still some wiring and seat mounts to finish up, but I like the direction it is headed now.
04-04-2018, 09:56 PM | #71 |
Front frame
I didn't originally convert this to air cooled- it was done long, long ago. The original builder used an XR200 motor, which I blew a head gasket on.
You can see in this picture that he cut the drop from the front of the frame and added the square tubing: |
04-08-2018, 06:14 PM | #72 |
Zong powered CR125 battery relocation
Decided to mimic the way a good friend setup his electric start bike.
Made a mounting tray out of aluminum- it's hard to see, but it bolts on with the sprocket cover. Two holes on the far side allow it to be aircraft safety wired to the case vent pipe. Good centralization of weight and shorter/less wiring. I also zip tied the battery to the tray after this photo was snapped. From kick side: Last edited by ChondaChondaChonda; 04-08-2018 at 06:51 PM. Reason: clarity |
04-08-2018, 06:21 PM | #73 |
The solenoid is now mounted on the other side of the starter; now wires are used. Its a "bus bar" made from aluminum and covered with heat shrink. The bus bar to the solenoid is about 1" long and holds the solenoid in place:
The positive to the battery is also an aluminum bus bar covered with 2 layers of heat shrink. If you look at the picture close you can see it curving over to the positive on the anti-gravity battery. Nice drip of fuel there too. I also took my old Pitster kickstand and front number plate and repurposed them to this old Chonda: It's really starting to come together: Rode it around the back yard for a bit. Made adjustments to the handlebars and controls. Really liking how this feels now. Planning to take it on a big desert ride tomorrow to test it all out. |
04-08-2018, 07:11 PM | #74 | |
04-08-2018, 07:25 PM | #75 |
I'm guessing it's a resonance chamber. Sometimes called helmholtz chambers.
From Wikipedia : The theory of Helmholtz resonators is used in motorcycle and car exhausts to alter the sound of the exhaust note and for differences in power delivery by adding chambers to the exhaust. Exhaust resonators are also used to reduce potentially loud and obnoxious engine noise where the dimensions are calculated so that the waves reflected by the resonator help cancel out certain frequencies of sound in the exhaust. In some two-stroke engines, a Helmholtz resonator is used to remove the need for a reed valve. A similar effect is also used in the exhaust system of most two-stroke engines, using a reflected pressure pulse to supercharge the cylinder (see Kadenacy effect.) Probably just for looks on this pipe. |
