Old 11-10-2016, 10:11 AM   #61
95C1500   95C1500 is offline
That's what I figured. Thanks for the input!
Old 11-10-2016, 10:21 AM   #62
Merlin   Merlin is offline
Your welcome.
Old 11-10-2016, 10:57 AM   #63
Once you weld them in your done. You have to live with it. I think it a design to be able to replace the studs in case of sheer off.
Old 11-10-2016, 11:33 AM   #64
The design is quite good, and is borrowed from Honda. Those studs sit in bushings, and the entire assembly is meant to have some give upon engaging the clutch. It saves wear and tear on the chain, sprockets and you.
Old 11-10-2016, 06:20 PM   #65
I knew there had to be a reason. Thanks for the replies.
Old 11-11-2016, 11:36 AM   #66
I should have added that the setup is commonly referred to as a cush drive.
Old 11-11-2016, 11:57 AM   #67
Question
I wonder if my new hub is cush? It has bolts not pins. But the bolts bolt up to inserts in the hub that can move kind of like the pins.
Old 11-12-2016, 02:18 AM   #68
Took pictures of it. This is really the only good one.
Went out tonight to grease the front axle (my God did it need it) of all things and.... of course this is where I ended up. Front axle greased, swing arm greased, coilover greased, I tried my best to clean the chain with what I had available bu it'd didn't wok so great, cleaned the front wheel, wiped the gunk off the motor/frame/swingarm. I went a lot deeper into this than I thought I would.
Still waiting on my JT rear 45t sprocket to be delivered to the amazon seller so they can send it to me. Only ordered it a month ago. They are supposed to receive it on the 15th. It'll probably be delayed ANOTHER two weeks.
Old 11-13-2016, 12:06 AM   #69
Good work 95c1500. I just greased my speedo cable . Just pull it out from the front sending unit...easy
Old 11-13-2016, 04:45 PM   #70
GeneralTso   GeneralTso is offline
GeneralTso's Avatar
Bike looks great, good job. Reminds me I forgot to grease my front axle when I did the bearings! Damn...
2005 Kazuma Cheetah 200 (Swamp Thing)
Old 11-13-2016, 05:34 PM   #71
Adjuster's Avatar
I lathered up my swing arm bolt with silver anti seize. Made a huge difference in ride quality. I like the anti seize for stuff like this. It sticks to anything and seems to be impervious to water etc.
Old 11-14-2016, 01:36 AM   #72
Do you still have the stock custer?
Lol!
Hm. I might have to pull it back out and do that. It'll be a little while though lol
Old 11-14-2016, 10:30 AM   #73
I have the bashan bike, analog speedo.
Also, did you find the kickstand spring http://therps.net/DB-Hawk.html
Strange how the spring is not listed under the misc tab
No dreaming about dirt bikes during class
Old 11-14-2016, 09:22 PM   #74
I have not found a spring. I was thinking I could find something at Ace or Home depot
It happens all day every day lmao
Old 11-15-2016, 12:18 AM   #75
I'd like to see a picture of that.
