Old 07-18-2016, 12:56 AM   #61
Slopeflyer   Slopeflyer is offline
Slopeflyer's Avatar
Anyone know where to get a leaner pilot mixture screw for the stock carb. I filed a slot in the screw and checked where it was positioned. Removed it, cleaned the sealant out of the threads and seated it. Turned out 3/4. Was at 1. While monitoring a tach, it continued to idle normal with it fully seated, no increase in rpm's. Explains why it never needs choke.
Old 07-18-2016, 01:53 AM   #62
pcspecialist   pcspecialist is offline
Where in Oregon?
Old 07-18-2016, 11:26 AM   #63
rojo_grande   rojo_grande is offline
rojo_grande's Avatar
Here's a PZ30 rebuild kit that has a replacement pilot screw.
http://www.ebay.com/itm/291807976434
'15 RX3 (Rojo's)
'15 RX3 (marzhere's)
'16 TT250
Old 07-18-2016, 05:43 PM   #64
moparrob   moparrob is offline
The idle mixture screw is standard and does not need to be replaced. When the symptoms are as you indicate the proper response is to use a leaner idle jet.
Old 07-19-2016, 11:48 AM   #65
Slopeflyer's Avatar
Thanks for the clarification. I forgot there was a idle jet stamped 38 in between the main and the mixture screw. Makes sense now.
