Old 03-28-2014, 10:18 AM   #61
I haven't messed with the rear shock, other than to remove the spring for cleaning and painting.
Old 03-28-2014, 02:02 PM   #62
Please remind me; what bike do you own? However, I seriously doubt your Chinese shock absorber is rebuildable.
Old 03-28-2014, 02:40 PM   #63
stretch8668   stretch8668 is offline
Its a 2007 cool sport co200gy
Old 03-28-2014, 03:24 PM   #64
I'm confident your shock is sealed, and cannot be rebuilt. Only expensive shock absorbers can be rebuilt.
Old 04-14-2014, 12:44 PM   #65
Where can I find this switch I've looked but cannot find it and would like it to be a us seller. Reason why I'm asking is because the right turn signal only works when push it over and press down I have seen similar ones just not one with choke. Mine is lights on/off park light high low turn signals horn and choke
Old 04-14-2014, 01:44 PM   #66
I bought one of these for my Zong from AliExpress.com.
http://www.aliexpress.com/item/Motor...472211033.html
Old 04-14-2014, 02:36 PM   #67
The plugs are different and I'd like a plug in so don't have to cut wires I'm at work now put ill take pics tomorrow
Old 04-15-2014, 10:28 AM   #68
Took switch apart and there was a sticker with 165 on it must be the part number as there's no other numbers on it
Old 04-15-2014, 11:29 AM   #69
After took switch I relized that its fine its a mfg defect cause the arm that accurates switch isn't allowing it to move all the way over. so gotta press switch in when turn it to right to acivate it.
Old 04-15-2014, 11:53 AM   #70
Is there a part of it that can be trimmed or filed to fit?
Old 04-15-2014, 12:19 PM   #71
Yea I'm gonna its the part on right side of switch ( the longer end) I'm gonna try to match it to the other side so it'll be symetrical. I'm also gonna get some electrical cleaner and disconnect and clean switch as there's a maginal amount of corrosion and lube it with petroleum jelly. Also gonna use petroleum jelly on case where the two halves contact to seal it so no water gets into it.
Old 04-19-2014, 09:04 PM   #72
Took bike out today for a while here's some pics love the scenery here in nh
Old 04-21-2014, 10:51 AM   #73
Took swing arm off today and found out its not the bushings but the bolt the bolt is a 1/2" and one I need is a m14 had fastenal order me one. I also need some washers cause one bushing doesn't contact either side of frame makes me think some one replaced swing arm.
Old 04-21-2014, 11:49 AM   #74
Could be. Could also be poor fitment from the factory. I've had to shim stuff like that to make everything work properly.
I'd recommend machinery bushings instead of washers. They are not too costly, and they're available in several widths and thicknesses. Should be available at Fastenal. Glad to hear that Fastenal had the 14mm bolt size available.
Old 04-21-2014, 12:05 PM   #75
They have to special order it at $33!!!!!! But ill feel safer with it on
