#61 |
Im only looking for one. lol If you run across any 8mm, take a pic. I might just snag one or two right side.
#62 |
it just happens I have one that is standard thread 8mm that I bought on accident a long time ago, I can get a picture a bit later.
Dune buggy build http://chinariders.net/modules.php?n...wtopic&t=14470 400cc lifan build vid: http://youtu.be/20HoU8OK_Y0 other fun: http://tinyurl.com/wildalaskan |
#63 |
yes sir, I did the opposite. Ordered a 10mm and now have adapters on the way... lol
#64 |
#65 |
really cant see it in the pic.
#66 | |
#67 |
Wild_Alaskan - do you have a speedometer / tach assembly ?
#68 |
Last chance on these parts, still have some odds and ends left, the rest will be tossed in about a month.
#69 |
Please update us on what you have, WA.
#70 |
any chance you have a 18" rear wheel with disk brake on it?
#71 |
no good rear wheel parts.I will try and make a list tonight.
#72 |
here is all I have
BODY One gas tank with two keys two side covers (front halfs only) Right side gas tank shroud (red) both sides gas tank shroud in aluminum black diamond plate Bar pad mirror (right side) mechanical tach and speedo cluster no ignition electric tach an mechanical speedo cluster no ignition throttle tube and housing FRAME one heavy duty chain adjuster one slightly modified chain adjuster speedo cluster mount complete triple clamps forks, no leaks, questionable dampening action exhaust heat shield front brake caliper rear brake drum front wheel seat release mechanism rear wheel spacer ENGINE/ELECTRICAL One complete engine BAD CYLINDER, HEAD, VALVES, SPROCKET COVER. CAN REMOVE ANY NEEDED PARTS One possibly working wiring harness Carburetor intake two 4 pin regulator rectifiers
#73 |
You can have any or all of it for pretty much the cost of shipping.
#74 |
Can you measure the mounting points on the front brake caliper bracket? Need about 60MM between the bolts where they mount to the fork (left side). Just noticed my hi-bird only has on bolt in it. The second one doesn't line up, someone changed it.
Edit: Well heck, if you've still got the forks and wheel, I may as well just take the entire assembly. That'll solve my issue. If you remove the springs and compress the forks, it should reduce the box size and shipping costs.
2000 HD XL1200C 2006 Hi-Bird QH-250-GY 2004 150CC Dual Sport (Chongqing Xgjao) 1978 Honda CB750K 1977 Honda GL-1000 (Goldwing) Project/Parts bikes 1977 Honda CB-750K 1977 Honda CB-550F Last edited by rich_e; 08-06-2015 at 01:10 PM. |
#75 |
Sorry all these parts are gone.
