Old 09-13-2012, 01:52 PM   #61
Almost always you can drop a tooth on the front with the stock chain unless it was worn out to begin with. Even then some will remove a link or two but I try to not do that.
One tooth off the countershaft will make a decent difference. YMMV but I think on bikes I've done the math on in the past it was about 11%.
Old 09-13-2012, 02:21 PM   #62
You can keep your existing rear sprocket, but if it's worn out, it will quickly wear out the new chain and countershaft sprocket.
BTW, you can go as low as 12 teeth on the countershaft sprocket and make a wheelie machine.
Old 09-14-2012, 01:27 PM   #63
450-WheelieBoyz   450-WheelieBoyz is offline
Send a message via MSN to 450-WheelieBoyz
i could put a 12 tooth front sproket without shortening the chain or changing the rear sproket?! 12:48!
ah yah! wheelie machine eh?! that was what i was going for XD :twisted:
WELD!
-Concerning the Mikuni i odered, you told me to get a 110 Main and 25 Slow .
-Is this identical or equal to the stock jets in the PZ30?
-Or one size bigger?
-Everyone says these bikes are jetted for 150-200cc...i want it to be jetting for a 250cc !
-Can you send me a link to a site or ebay seller that has compatible sprokets for my 2011 Gio x31 250cc OHC ?
- I have never tuned a carburetor before, any tips on how i should go about setting my jets and stuff?
thanks again boyz, Im excited to receive my parts! :twisted:
Old 09-15-2012, 12:00 PM   #64
I'm not saying that you can change to a 12 tooth countershaft sprocket without shotening your chain; you will most likely need to shorten it. I'm only saying that you can safely go as small as 12 teeth (11 teeth is too small for the chain to properly articulate).
I presume that the jets I recommended are larger than the Keihin jets, but that's not the real point. As you say, you want to jet for a larger engine (your bike is actually closer to 230cc, not 250cc). Try the jets I recommended first, and go larger as necessary. If you have a muffler with no restriction and the new air filter, you might need to go as high as 115 main and 30 slow. The idea is to have the air and fuel in just the right proportions to make maximum power.
There is no tuning necessary on a carb like this, except to set the idle to a low speed that will still idle and set the pilot mixture screw for a smooth transition. You'll see when you get your new carbs that the slow jet and main jet simply unscrew; nothing to it. The pilot mixture screw is responsible for the transition from slow jet to main jet without bogging. Just gently tighten the pilot mixture screw all the way and then loosen it 1.5 turns. Let us know how that works.
For us to guide you with sprockets, we need to see them. If you remove the front sprocket and take a pic, we can go from there.
Old 09-16-2012, 09:17 AM   #65
thanks a bunch, i just need install the jets, set the pilot screw to your recomended specs, and plug it in and set the idle.
should i set the idle when the bike is cold or warm?
the giobikes site does give much at all. i counted 15 teeth....
6 steel front sprocket 11-31-06
http://www.giomotors.com/catalog/Dir...-/Stock+Parts/
13tooth
-http://www.chinapartsdepot.com/shopping/shopexd.asp?id=441
14tooth
-http://www.chinapartsdepot.com/shopping/shopexd.asp?id=438
thats all i found, that i believe could be compatible....
Old 09-16-2012, 09:30 AM   #66
are there any threads on chinariders on how to adjust a throttle cables??
did goofyexponent every say how he went about adjusting his hydraulic clutch lever?
thanks in advance boyz
Old 09-16-2012, 12:30 PM   #67
Yes, final adjustments to the carb should be performed when the engine is warm.
Here's what I think you have for a front sprocket, but you'd need to remove it and measure it to be sure:
You can get the above sprocket in 12, 13, 14, 15, 16 or 17 teeth. I'm guessing that your chain is a 428.
I don't recall seeing a thread on adjusting the throttle cable; do you have a specific question? I haven't seen anything on the hydraulic clutch yet.
Old 09-17-2012, 02:15 PM   #68
i just wrote to the Chinapartdepot, and asked if they had sprokets that they were sure would fit my ride...
im not missing much to complete the project! i will update soon, thanks again everyone
Old 09-17-2012, 02:58 PM   #69
The sprocket I posted a pic of is easily found at your local motorcycle shop, and it will cost around $12.00-$15.00. It's from an XL125.
http://www.jtsprockets.com/catalogue/model/5004
The rear sprocket that is pictured in the link will not likely fit your bike; only the front one will.
Old 09-17-2012, 04:43 PM   #70
thats great, i really didnt want to buy a sproket from china. i thought it was my only option....
I will be stopping at my local bike shop to buy and order some more goodies!
Cheers hopefully ill get the bike to run like Goofyexponent's :P
thanks again boyz, couldnt have done it without you
Old 09-18-2012, 02:06 PM   #71
test
Old 09-18-2012, 02:18 PM   #72
Loud and clear.
Old 09-18-2012, 02:26 PM   #73
lol
just figured out how to attach my signature
450-WheelieBoyz a.k.a. BlockHustler1000
-2011 X31 Gio 250cc-
Mikuni Upgrade
Air filter
Hydro-clutch
Reppin -> Montreal, Quebec, Canada
Old 09-21-2012, 11:51 AM   #74
Air filter and hydro-clutch just arrived!!
now im just waiting for my Mikuni to arrive
going shopping for some goodies tonight XD
i guess the rebuild will start next weekend XD
sheS gonna FLYYY
Mikuni Upgrade
Air filter
Hydro-clutch
Old 09-21-2012, 12:39 PM   #75
I got my popcorn and Coors Lite ready to go!
