07-10-2016, 12:01 AM | #61 |
Had you shown a pic of it before running it I woulda warned you that it would melt the plastic. As for the bolt, yes it got too hot too.
07-10-2016, 03:39 AM | #62 |
Hey I was not thinking very well
2016 TT250 2014 NSS300 FORZA 2014 UN200 BURGMAN |
07-10-2016, 04:40 AM | #63 |
what about airbox clearance,melting?
07-10-2016, 04:43 AM | #64 |
Air box is free and clear I had to a just the cluch cable some but it freed to I was just a boon head with the license plate mount but it is fine itcleaned up and is no big deal but it was more than worth it
07-10-2016, 04:53 AM | #65 |
Did you have to drill out the flange to be larger or was it a perfect fit already?
*2016 CSC TT250 *2006 Zongshen ZS200GY-2 *1973 Honda SL100 |
07-10-2016, 07:02 AM | #66 | |
07-10-2016, 07:05 AM | #67 |
OK this is hoe I did flange
Cut the top of on bolt hole and use good washers probably will check bolt often
07-10-2016, 07:09 AM | #68 |
The middle just bolted right up but to raise the muffler up I did this with a very strong clamp to pipe right under air box no frame cuts or weilds
07-10-2016, 07:13 AM | #69 |
Run muffler as far into pipe as you can and use stainless steal zip tie
You can bolt it through where the hand grip bolts to the frame but it will require some grinding and you would have to cut original mountil to be cut off did not want to do that
07-10-2016, 07:19 AM | #70 |
For now everything looks good and exshaust is not melting anything
I will look for a more permanent solution if it is necessary but it is good for now I am going to be at my friend shop later this week and I am sure the grinder and the weilders will make its way into the picture Took it for a run and it is so different also top speed is one 68 it was 64 but the real difference is in the middle gears 2 through 4 pull like hell
07-10-2016, 07:45 AM | #72 |
This thing feels like a leaf blower put you hand behind factory exshaust and it feels like it it tring to push out a popcorn fart the pipes that lead to muffler are much bigger and the exhaust hole is big enough that you can almost stick your hand in it spark arrester is clearly visible not hangers required
Free and open exshaust that does not chock out your power Thanks for all the tips and links to videos I watched them all and used some things from both and threw in a few of my own I hope this helps and if any of you guys do this and see something I missed please let me know And please no noise from the peanut gallery about the melted fender I am the first one to pull the trigger on the TT250 SUPER MODS
07-10-2016, 10:07 AM | #73 | |
2016 CSC TT250 |
07-10-2016, 10:23 AM | #74 |
Out of curiosity, would it be possible to affix the aftermarket canister to the stock header pipe? That would seem to avoid alot of the problematic mounting and clearance issues.
07-10-2016, 11:08 AM | #75 |
The new one is bigger and has the bulge not sure what bulge is for but hey for 140$ I wanted it
