Old 08-26-2024, 12:12 PM   #61
cheesy   cheesy is offline
cheesy's Avatar
booger zapped
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 08-26-2024, 05:00 PM   #62
TominMO   TominMO is offline
Originally Posted by cheesy View Post
booger zapped
OMG you are so immature.
Poop!
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle. Nope, finally retired.
Old 08-26-2024, 06:40 PM   #63
cheesy's Avatar
Poop!
Sad, isn't it.
Growing old is mandatory. Growing up is optional.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 08-26-2024, 07:01 PM   #64
Thumper   Thumper is online now
Originally Posted by XLsior View Post
So looking under the Crunchy LWB after discovering the exhaust pipe snapped..
Clean break from mostly fatigue and perhaps some help from rust...
Whipped out the 140amp gasless welder, did some rough prep and also cut out a section of pipe from the junked SWB exhaust pipe to make a support sleeve/collar...
Don't under sell your skills
Damn nice fix. The sleeve was a great idea. Who cares if it is fully sealed. Won't hear it! I welded a small mounting cylinder to my trailer for a swing-away jack. I chose the wrong stick and applied way too much amps at the start! I realized that the little cylinder was pretty soft, moved to a thinner stick and dropped the voltage, then proceeded to make a nice lumpy mess. It will hold OK. Overbuilt. But gee, I need much more welding time
No matter where you go, there you are
Old 08-26-2024, 07:07 PM   #65
XLsior   XLsior is offline
XLsior's Avatar
I could not be f'd stacking dimes under a crusty van...
Booger zapping is about as accurate as the methodology is described...
Stronger than throwing popcorn...
I'm old enough now where pooping is a highlight of my day...
Old 08-26-2024, 10:40 PM   #66
XLsior's Avatar
Old 08-26-2024, 10:45 PM   #67
Great movie.
2022 Lifan KPX
Old 08-27-2024, 08:44 AM   #68
cheesy's Avatar
I usually call it 'Stacking Nickels' and 'Hanging Grapes'. Nickels or dimes just aren't an option when space is limited.
A couple cups of black coffee in the morning will usually get things 'moving'.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 08-27-2024, 09:16 AM   #69
And more veggies and fruit.
2022 Lifan KPX
Old 08-27-2024, 09:33 AM   #70
XLsior's Avatar
Yes well we're all dollars and cents in Aus along with mostly metric though imperial still gets thrown around.
Nickles and Dimes are foreign to me...Smallest coinage we used to have was a 1c copper/nickel coin before that got removed out of circulation and 5c became lowest mintage.
As far as welding and fecal matter is concerned you want be somewhere between rat sh1t and bird sh1t...
I call it booger welding when you're laying on your back looking at the underside and welding around an object blind on one side....
Old 08-27-2024, 09:36 AM   #71
cheesy's Avatar
It's all coinage.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 08-27-2024, 09:54 AM   #72
XLsior's Avatar
I'm a 2 coffee guy in the morning but if things arn't moving
I find lentils to be a good promoter.
Old 10-23-2024, 11:38 PM   #73
XLsior's Avatar
Derpin Around with diesel pump timing
Since the Motorcyle decided to snap a push rod and the Auto crunchy parts van is leaving transmission fluid leaks where I park it after running...
Derpin the main van needed to shake off some cobwebs and dust from sitting in the garage for months now...
Before playing with the pump and putting all the bits back into it I put the diesel compression test kit to work, I wanted to confirm that my cylinder head and gasket job was actually successful or if I actually fumbled hard...
Results however are cylinders 1/2/3 hit 380psi with cylinder 4 hitting 400psi.
Which is about smack bang in the middle of specification and well within deviation tolerance.
So with that pat on the back I needed to confirm it was indeed an injection timing issue...
the stock/prior timing mark was center aligned...clockwise down the engine stumbled and chuffed white smoke more often with a shuddering...
counter/anticlockwise up things improved to the point I would call drive-able granted there's a couple of coolant leaks to sort out...A bit sooty but smoother...though still not perfect when compared to the parts van auto engine...
Anyway I have forwarded this same relevant info to the diesel pump workshop to perhaps confirm the Anticlockwise position indicates the pump is out 1 tooth...
Still nice to be out of the garage for a wash down and sunny air out at least.
Also remember to connect the diesel return line before running, your garage floor will thank you...
ID:	32172   Click image for larger version
Old 10-24-2024, 07:35 PM   #74
XLsior's Avatar
Word back from the Diesel pump service center is they still believe I did something incorrect.
I am at the stage now where i might have to swap pumps just to prove a point without a shadow of doubt, That either I did get it wrong, or the serviced pump is faulty....
