#61 |
More awake this AM, Would not siphon as the squirt holes over the rockers would suck air 1st............
#62 | |
If I were going to install one, which I likely won't; I would plumb the inlet to the lower cooler hose and use a check valve, no drain-back and no trapped air. I would also pre-fill the cooler and hoses before the first start-up. After the install I would check the oil level regularly before starting to assure it's not draining back. |
#63 | |
Thank you, Kohburn; I failed to mention that part. I do like the concept of creating a vacuum in the bottom end of V8 motors in drag racing applications, but I don't know what the long term reliability would be.
#64 | |
On the supply side what is the likelyhood it could suck back through the oil pump? If that's the case the engine would always start dry anyways. On the outlet side it has the squirt holes. Mountain out of a molehill IMHO. I ran a diesel performance shop in Florida for many years and we routinely took check valves out of the Dodge 47RE transmissions to provide more oil flow to the cooler. This is well documented and many forums and it worked. I would think if their was going to be any issue, Wolftrax with over 2,000 miles on his cooler would have had them. That said, If you are bothered, A Banjo Bolt check valve is available for $20. https://blaisracingservices.com/ktm/...mog-p1270.html |
#65 | |
#66 |
I really think drain-back is a not issue. the hawk motors have had the simple cooler installed with only positive effects.
#67 |
Msjft.. as far as the can't be done folks, I say this is good to talk it out and Bulletproof the design. One thing I might add in your development, could you use the transparent hose to observe the oil during the initial start/flow process. It wouldn't even need to be run long so the heat on the hose would not be relevant for the short testing period . With the ability to see what the oil is doing you could best position the cooler/ hose routing etc.
1 in. x 3/4 in. Vinyl Braided Tubing or equivalent? They have heavy duty fuel rated versions too.
#68 |
Yes, I enjoy them as well. I learned 90% of what I know from playing with BSA Goldstars, AJS 7R's, and Aermacchi Harley Davidsons. And I learned what NOT to do on my Ariel Red Hunter and My Ajay 350. The Aermacchi was great - a whole different approach to getting the same result. First at the checkered flag. I wasn't a good enough rider to win, although I loved racing in Southern California TT races. Prado Park was my favorite track to race on. A fast, but nasty dirt road racing track. I don't mean dusty I mean nasty like the kind of pitches that Clayton Kershaw or Jake Arrieta throw.
#69 | |
The transmission comparison has no relevance. |
#70 | |
Caged ball bearings on the crankshaft, caged roller on the big end bearing.
![]() Quote:
#71 |
10 mile ride this afternoon at 92* ambient temperature. Case temp 215* Cylinder temp 245* when i got back, Cannot get the bike into neutral without shutting it off or going back and forth from 1 to 2 10-15 times and getting lucky. Running 1/4" Clutch free play. DO NOT have this issue when it's in the 50's. That is why i started looking into this in the 1st place. I just think heat is expanding things enough to cause this. Bike has a little over 300 miles on it. The other bike from the 2 pack i bought does the same thing..........
#72 |
maybe its old school, but i was taught always to shift into neutral as i rolled to a stop, the idea being having the clutch suddenly bind, or a cable let go, you wouldn't be launched out into traffic or an intersection- which could b baaad
#73 | |
#74 |
Actually just ordered a 13 tooth for where i ride.....
