08-01-2011, 12:58 AM | #46 |
Ah hell I was installing my new off road tires and managed to do this exact same thing and cracked my front fork wheel axles holder, it didn't take much torque on the pinch bolt at all.
It sounds like there is not much luck getting a replacement part as the right side fork assembly seems to be what you can order. It looks like the piece should unbolt from the bottom but with konker out of business I'm sure it won't be easy to find a fork let alone this piece. I'm going to look into having it welded locally here. :( Damn I was planning to take it offroading tomorrow too |
08-01-2011, 01:04 AM | #47 |
Maybe you can get that part?
B451 QM200GY-B(A) F43A-13 Front Wheel Bracket $90.00 http://www.konkermotors.com/pdfs/ret...rtsPricing.pdf The konker manual seems to suggest you can, I'll have to see what this part is on the Qinqqi |
08-01-2011, 01:08 AM | #48 |
Interesting qingqi doesn't list the Front Wheel Bracket as a seperate part http://www.qlinkmotor.com/uploaded/P...rts%20book.pdf
like Konker does |
08-01-2011, 01:18 AM | #49 | |
08-01-2011, 01:42 AM | #50 |
I'm sorry to hear about the damage to the right fork on your Konker motorcycle, Granter. :( I agree with Stew. I think your best bet is to get someone in the U.S.A. to ship you a new right fork purchased from QLink.
08-01-2011, 01:59 AM | #51 |
Yeah worst case I see the fork there for about 300. I'm going to see about the welding on Tuesday, and also sent qlink an email referencing the konker part to see if they sell just the part I need as another option.
08-01-2011, 01:56 PM | #52 |
Bummer! :evil: I'm wondering if there may have been a casting issue with a group of these or something?
I've had my Q wheel on and off a half dozen times now without a problem! :? Strange........ 8O
08-01-2011, 02:09 PM | #53 | |
08-01-2011, 02:19 PM | #54 |
Bummer.
From my recent experiance with the world of welding aluminum motorcycle parts it probably can be done but you may hve to take it apart first. Plus I don't know how well the rest of the fork will hold up. On the other hand who knows how long a new part will last as this is the second failure of this type we've seen. My guess would be a metal quality or casting issue. :?
Happy to serve. |
08-01-2011, 03:18 PM | #55 | |
08-01-2011, 04:24 PM | #56 |
I agree. Plus if you think about the way the bolt is stressed it really does not have to be very tight. I'd say 10 ft/lbs and maybe a dab of blue Loctite would be fine. I'm happy I did not have a problem with my Q's in this regard.
Happy to serve. |
08-01-2011, 06:13 PM | #57 | |
08-01-2011, 07:41 PM | #58 |
This reminds me of the old 'Check the swingarm pivot of your Lifan because it's gonna fall out' issues we've dealt with in the past. That was also good advise. :wink:
Happy to serve. |
08-03-2011, 12:50 AM | #59 |
Had the part welded with a tig welder, had a mandrel inserted where the axel goes during the welding to keep things round. Here are some pics of the weld. I painted the part but didn't have the original silver color so it's a little daker grey now.
08-03-2011, 12:53 AM | #60 |
Incase anyone is curious, you can remove this piece, dealers will tell you that you can't. There is a little allen bolt that you have to undo, then heat it a bit and tap it with a piece of wood and hammer to turn it while holding the shock.
It jsut screws on, here you can see the threads, it's a bugger to get off though. I filled the shock back up with 10 weight 330 ml of fluid. Putting the shock together was pretty easy, nothing really unique about it except for the bottom in the shock you have to line the end of the shock up when you reassemble it which is a bit finicky. |
