Many answers lie in a high resolution close up photograph of that plug.
Happy to serve. |
#2 | |
#3 | |
The fuel mixture however, is, at least here in Europe, set far too lean overall. The obsolete engine designs and basic unsophisticated carburettors make this obligatory for the makers if they're to meet emissions regulations. Most just scrape-by. All of my bikes hace benefitted from tweaking the jetting and other carburettor parameters to obtain satisfactory mixtures right through the range. My Qingqi's (Qlink XF200) Mikuni carb runs better with 125 main jet, although it came with a 122.5. That's two sizes up from OEM specs. Curiously enough the Brazilian Qingqi QM200GY models (called STX Sundown) has an even larger main jet as standard, 127.5. Even so mine still a bit on the lean side and will be changing to the larger jet shortly.The needle setting came on the third groove from top, the Brazilian specs are on the fourth groove and so on.Their emissions laws are not quite as strict as ours. Over-lean mixtures are the cause of lots of running troubles, poor starting, cold-blooded engines that take ages to warm up, poor throttle response and slow running. Continous, sustained full throttle and high revs with a lean mixture can have a devastating effect on engine internals. Basically the makers don't care as long as they get the homologation certificates. Eventually they'll fit electronic injection and engine management systems on the bikes and all this will be solved.
Jincheng Monkey JC50Q-7 (two of them) Skyteam Dax replica ST110-6 (two of them) Zongshen ZS125-43 Qingqi QM200GY-BA Super Motard Yamaha Virago XV1100 Triumph Bonneville SE Qingqi QM110GY PGO Bug rider 250 Buggy |
Over-lean mixtures are the cause of lots of running troubles, poor starting, cold-blooded engines that take ages to warm up, poor throttle response and slow running. Continous, sustained full throttle and high revs with a poor mixture can have a devastating effect on engine internals. I BET that's what did PizzaRider's engine in. Maybe those of us with stock jetting need to richen it up a bit.
Happy to serve. |
I think it was running lean. That piston looks to have melted. I changed from a 98 to a 108 main when I changed the exhaust and air filter. I think alot of these bike could be be bumped up one or two sizes without mods.
Really for the number of bikes here I think there have only be a handlful of engine failures like this. Allen
#6 | |
Chinabikeless |
I was originally planning on leaving my entire system stock, presumably for the purpose of reliability.
With this new information, I'm thinking that maybe ratcheting up my main jet would be a smart way to go. And of course if I'm going to do that, I may as well put a pipe on it. I would probably leave my airbox and induction system stock, this just gives me more to think about.
Happy to serve. |
That piston totally looks melted from an overlean condition.
Happy to serve. |
I'd really like to see that plug also. i'll second that overly lean condition. Usually the piston makes a big BANG when it lets go, but yours appears to have melted down. When you tear down the engine, let us know what setting the needle in the carb was set at, and also, what jet you had in it.
at least we now know we apparently have cast aluminum pistons. seer
#10 |
Here are two cell phone pictures of my spark plug. Sorry for the quality but this is all I can do. -Cory
http://chinariders.net/gallery2/main...serialNumber=1 http://chinariders.net/gallery2/main...serialNumber=1 |
#11 |
its awefully white.
#12 |
It does look awfull white.
#13 |
Yep too white. Lean condition. The porcelin part should be a tan color when the fuel mixture is correct.
Diagnosis. Fuel mixture loo lean at 3/4 to WOT. Piston starting get hot. Detonation started to occur and piston started to melt resulting in piston failure which in turn destroyed the top end. Preventative measure. Larger main jet. I don't think the higher octance gas would have made that much difference. It was more a lack of it. Higher octane may have bought you more time, but these engines don't run that high of compression. Allen
#14 | |
#15 |
I am no expert, but going with he probably has a stock 98 maybe to a 102-104. Two sizes max.
I would say you also need to account for elevation. I am 1100 ft. I have a UNI filter and an opened up exhaust and I run a 108 main. I could probably go to a 110 too. So others are running a 115 with similar mods to me. I am guessing they may be at a lower elevation. If you are in Florida you probably need to up it some more on a stock bike. Good read on jetting. http://www.4strokes.com/tech/4sjetting.asp Even jap bikes can be jetted "wrong" from the factory. Elevation plays a big part. Allen
