Old 09-20-2008, 01:35 AM   #46
Jim   Jim is offline
Yeah just the tail lamp and signal lights... I'm going to probably hold of a few months, I've recently made some large purchase's and just don't have the money, but I've got it bookmarked...
The stock taillights aren't overly bright, and I've always been a fan of led's... I put one on my quad and my gy5, but they were both just off a commercial truck (60 diodes).... For this bike though I want it to look right.. As well as being overly bright.
"Be excellent to each other"
Old 09-20-2008, 08:05 AM   #47
tigertamer   tigertamer is offline
Another caveat: Although you will not need the bridge rectifier, you will most likely need to upgrade to an electronic flasher to preserve your flash rate. But they are relatively inexpensive and readily obtainable in most parts houses.
Let us know if you need a hand when you're ready to go with it :wink:
Good luck,
Tigertamer
07 H-D XL883C
06 LF 200GY-5
Yin and Yang
CAUTION
Obey The Traffic Regulation.
Always Wear a Helmet.
Don't Ride After Drinking Wine.
Before Operation, Read The Owners Manual Carefully.
Old 09-20-2008, 12:51 PM   #48
Jim   Jim is offline
Yeah I figured I might need to do that.... It's not like the stock one is very special anyways, I was going to replace it to silence the beeping, but it was easier just to stuff it with foam since I had that handy....
Old 09-21-2008, 07:06 AM   #49
The replacement of the "beeping winker" is the best side effect of the LED upgrade.
Thanks to MBLAS3, I have a color enhanced wiring diagram for an LF200 G-Y 5, that should be sufficient to use in case of any difficulty. The mod itself should be a simple task, but you never know when you might encounter the occasional "garage rash" while doing work on the bike.
Take care,
Tigertamer
07 H-D XL883C
06 LF 200GY-5
Yin and Yang
CAUTION
