#46 |
It is 4 am, so I have no way to check when I will probably get up at noon, I will record a diary on my motorcycle and compare them.
#47 |
On a quick comparison with the log file available in the ben elli TRK 251 program you can see the strange behavior here.
#48 |
It's 4am and I can't think too much anymore, but it looks like a crazy TPS sensor, but tomorrow er actually today I'll still compare it to my rx3.If the map sensor or tps is defective after some time from the bad mixture it will give a lambda error like the one you got.
#49 |
I made a log of my bike and compared you can see the problem with the throttle position you can clean it and check the plug contacts you can also replace the TPS I assume it is the problem you can look for such a TPS if the original one is expensive.
https://mega.nz/file/rMlnWaxL#ACQk_N...Hv4dhfG2crCcaU |
#50 |
Yeah, comparing those two data logs, I'm going to say there is something up with your TPS. Clean it if you can, replace it if you can't.
#51 |
I replaced the TPS, and it seemed to get better. I was riding the bike conservatively and the ECU corrected for the new TPS. Idle was rock solid stable, no codes, and the bike no longer hesitated or stuttered.
so then I took it on the highway and let it get good and hot, and the problem came right back. I replaced the MAP sensor, because it was easy to get to. No effect. So that leaves the IAC valve. That's the last thing I haven't replaced. Of course, now I'm feeling highly frustrated and severely pessimistic, and I'm doubting that the IAC valve will fix the problem. Which means ordering a new throttle body assembly and throwing even more money down the tubes. I'm not pleased at all. It's extra frustrating because I keep missing going on trips on the RX3. I *LOVE* riding the RX3. I love the size and the off-road capability and the light weight. But this will be the THIRD trip this year that I've missed due to the bike breaking right before the planned trip. This will be the third time I ride my absolutely trouble-free Benelli Leoncino instead. Charles. |
#52 |
Very strange things, I wonder how the temperature sensor works in this motorcycle, I used to have this in my car and the problem was the temp sensor but in the program you can see that the temp is ok and other things raise questions, interesting that for some time it was ok I assume until it warmed up well
#53 | |
It could also be a bad electrical connection somewhere; it's OK when the wiring harness and connectors are cold, but it breaks contact once things start to heat up. Man, an oscilloscope would sure come in handy here. Probably wouldn't take more than thirty minutes or so to find out what and where the issue is. |
#54 |
Oh, I wonder what gearing it takes to get a RX3 up to 318 MPH?
#56 |
Charlie, if you can clear the errors and record the log file again and see if there are still errors replacing every part without finding the cause is not the best solution maybe it will work maybe not look that the throttle position at your place changes even though you do not add gas it is very strange because you control it and it IAC not the other way around it could be some kind of error in signal transmission check the plugs well spray gold contact or similar.
#57 |
So I've replaced:
TPS (CSC part) IAC Valve (CSC part) O2 Sensor (delphi cross-reference) MAP sensor (delphi cross-reference) I've also disabled and removed the charcoal canister and blocked off the vacuum port on the head. (I left the valve attached so as not to throw a code). The bike will idle normally for a while, and then start gaining revs as it heats up. dongle shows TPS percentage is slowly increasing, but the throttle is not moving. Bike runs like absolute shit and will eventually throw o2 sensor code. If bike is running and I unplug the TPS sensor, the idle immediately settles down. However, the percentage shown on the computer starts fluctuating wildly. So... this seems unfixable to me. I've already replaced all the parts that could possibly control idle, and nothing is working. Has anyone done a carb conversion? I'm sick of this bullshit. Charles. |
#58 |
plis do log file
#59 | |
#60 | |
When you swapped out the IAC, did you clean the passage in the throttle body? It almost sounds like something is opening up dimensionally as the bike gets hot, which is letting in more air in and causing the ECU to add fuel. The fuel trims in your log file will show this, if that is indeed what is happening. Oh, and I don't believe that the coolant temperature sensor has been changed, unless you forgot to mention it. I know what I said about the parts cannon, but at this point it's all that is left, apart from the ECU itself or an issue with the wiring harness. I realize that this is frustrating, it always is when you are tracking down something, but stick with it, you'll get there. |
