Old 01-20-2020, 05:10 PM   #46
Darth Racer's Avatar
Looks good
Old 01-20-2020, 05:58 PM   #47
Oddball Matt   Oddball Matt is offline
Appears to be using the exact same plastics as my Bashan BS200-S7 only the headlight shroud is different.
2004 Longjia Grido 50 scooter
1999 Cagiva Mito 125 Evo, Yamaha XV125 engine, Ducati SS fairings, getting turboed
1993 Yamaha GTS 1000
Ex:Bashan BS200-S7 `07 Streetfighter-quad
Old 02-09-2020, 11:42 PM   #48
Vwchisme   Vwchisme is offline
Going to do a oil change and valve adjustment. Based on what i read I picked up some Shell Rotella T4 15w40 Diesel oil. Is this oil fine? For the adjustment of the valves the values i came across are .002 - .003. I this correct? which one is the exhaust valve?
Old 02-10-2020, 01:49 AM   #49
franque   franque is offline
Yes, same (though I'd do 3 to 4 thousandths), the front valve, in front of the exhaust.
Old 05-14-2020, 11:39 PM   #50
Picked up a FMF muffler for $20, so decided to gamble and see if i could make it work. So tweaking but got it to work.
[IMG]Taotao ATV by ntrodriguez, on Flickr[/IMG]
Old 05-14-2020, 11:43 PM   #51
With the upgraded muffler the reservoir brake line, sits close to the exhaust. Rerouted the line away from the exhaust, now the line as a kink that i'm not to happy with. Anyone one what kind of hose they use for the reservoir brake line?
Old 05-14-2020, 11:50 PM   #52
Replaced the front shocks with RFY and swapped the wheels from the other ATV. How do you add air to them? Do you need a special pump?
