08-06-2019, 02:55 PM | #46 | |
Will any of these work? https://www.rockymountainatvmc.com/search/go?w=jets I would also like to clarify the air/fuel adjustment. My understanding is on the four stroke carbs when I am turning the screw counter clock wise I am creating a more rich A/F ratio, or allowing more fuel at idle. Is this correct? |
08-06-2019, 03:59 PM | #47 | |
The idle mixture adjustment on these carbs is an air screw. The more you open it (counter clockwise) the more air you let through and the leaner the mixture. On the stock carbs it is a fuel screw, and thus opposite.
08-06-2019, 04:04 PM | #48 | |
Also, do you know if the stock air box intake boot would fit on the PE30, or is a new air filter required? The Apollo uses the same size stock carb as the Hawk, and I would like to retain the stock air box if possible. Douglass |
08-08-2019, 02:00 PM | #49 | |
The stock boot would not work without adapting it somehow. you would have to make your own intake tube or run a pod
11-03-2021, 11:45 PM | #50 |
Hey so I am a complete noob and I'm getting my TBR7 in tomorrow and I have the Nibbi PE30 carb still in the box..which scares me because I feel like I'm going to screw something up already. Call it beginners anxiety. Anyway I read that the PE30 air filters are yucky but can't find a K&N filter someone suggested; I really like to order on Amazon. What Air filter can you recommend for the PE30?
11-04-2021, 10:28 AM | #51 |
50 mm is the outside diameter of the PE 30 inlet bell so a filter with a 48 to 50 mm mounting flange should work. I would suggest starting your own thread on your build for assistance.
