Old 06-20-2019, 07:50 AM   #46
PhildoScaggins   PhildoScaggins is offline
Yeah that should work, I can convert to mm. Thanks!
Old 06-20-2019, 09:25 PM   #47
scoot newb   scoot newb is offline
scoot newb's Avatar
What exactly do you want measured?
Old 06-21-2019, 10:34 AM   #48
Just the opening of the filter where it mates to the carb, please.
Old 06-21-2019, 01:22 PM   #49
scoot newb's Avatar
Okay cool. It is pouring rain out. It should die down soon. For now, if you're just looking for a filter that will fit this will https://www.amazon.com/gp/product/B000N5UCEG/
Old 06-21-2019, 02:19 PM   #50
51mm got it. thanks!
Old 06-21-2019, 04:45 PM   #51
scoot newb's Avatar
I was pretty sure it was but I didn't want to guess. I went out to measure, ended up installing a gear sensor and some how drained the battery. Since the battery was full moments before connecting the gear sensor, I thought I was blowing fuses left and right... even after removing the gear sensor. I thought I fried something and forgot all about taking a measurement. My bad.
Anyways, do you have another thread with pics of your bike? I remember you mentioned doing the swap a while back but I can't find the thread with photos?
Old 06-22-2019, 03:17 PM   #52
scoot newb's Avatar
The gear sensor swap works fine. I have no idea what cause the instant battery drain yesterday but today i put in the sensor again, everything lit except 5th then I dropped in the 17t front sprocket. I really like it now. If only I could get the top end dialed in. Main jet and maybe a new coil... IDK
Old 06-25-2019, 11:19 AM   #53
Whisky   Whisky is offline
Whisky's Avatar
From what rpm does it start to have problems? what does it do?
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 06-25-2019, 02:02 PM   #54
I don't, I'll post some soon once I get it 100% together. It's taking me forever. It's been raining most of the time so I'm not missing much. Maybe 10 days of riding since april.
Old 06-25-2019, 03:02 PM   #55
scoot newb's Avatar
It varies depending on the throttle position. It cuts out, it seems too lean or the coil is janky. Right now I am at 38/125. I was going to try 130 and see what happens.
On, the stock motor, when I put the new carb on, it 'bogged out' at high RPM that was too rich.
The 190 just putting around without opening it up is so much more usable than the stock motor all dialed in. It is true what they say about less vibration.
Old 08-09-2019, 04:33 AM   #56
Whisky's Avatar
FINALLY....zs190 in and running. This motor is awesome! With the 125 I didn't have to look at speed but now it's way to easy to speed, even in 5th gear it pulls, it definitely redefines the bike. Love it!!!
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
