#46 |
Remove the air injection system and make a block off plate. That's more than likely the cause of the back firing.
#47 |
Looks like a nice, smooth transition in the exhaust inlet to me. Last time I did that, I used a die grinder, but a Dremel works with some patience.
#48 | |
![]() Was considering removing it previously and now it has got to go before I burn up anything. Since it was late at night before the ride I had to invent something quick. Plugged air injection at the engine with a M8x1.25 bolt. Irrigation plug goes to the airbox with silicon sealant and a screw for the cut tube that goes into intake vacuum. So far so good no backfires! ![]() The exhaust has to be the best $100 spent on the BSR. It really wakes up the engine and the noise and stink is a worthy trade-off on the trail. Last pic is the front tire. It looks very off-center, time to redo the spokes!
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 Last edited by AresROC; 07-27-2019 at 07:22 PM. |
#49 |
Factory Air Filter
Ordered a new foam air filter, but still undecided if the original airbox should be a keeper. I ride dusty in the desert and I do like the aribox design, with its separate compartment for air injection/crankcase ventilation. Has rear facing ports and a built-in drain hole. Also the original filter is a pretty good size and easy to find replacement.
With 600 km's on the bike, there were some fine dust already inside the airbox! Looks like I missed one of the plastic molding tabs and it is pushing up the filter surrounds. Just noticed the rear fender is damaged from rides as well. I guess I ride pretty hard in the dirt the fender is bobbing up and down audibly during the ride and the tire ate into the fender. ![]() ![]()
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
#50 |
Do you have a link for those risers you have?
#51 |
Well the exact risers are not available from the store but here are the dimensions. And this one is similar: Riser
#52 |
Fender Eliminator
Installed a new fender! See thread here
#53 |
The rear shock is not working. Took it off and a friend will look it over to see anything can be done to it.
Shock dimensions: Eye to eye 305mm. Top 30mm. Bottom 40mm. Also noticed the rear brake line is pinched probably to the rear passenger foot peg... time for brake line upgrade? Also air inject plug thread ![]()
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 Last edited by AresROC; 09-24-2019 at 04:40 PM. |
#54 |
Broke chain guard! Looks like one more item to chop off the bike
#55 |
Have you thought about a digital speedo?
If you are and willing/able to assist in some basic info I’ll do you a very good deal on a unit of your choice. |
#56 | |
#57 | |
My guess is for counter-sunk hex head plug to prevent handle bar from rotating? I also saw a guy who put a riser on top of the riser to raise the handle bar. Would be an interesting place to mount my NIB Evo SS Gimbal for GoPro. Almost had that Gimbal for a year now lol.
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 Last edited by AresROC; 09-13-2019 at 12:27 PM. |
#58 |
1000 KM/ 600 Mile Update
Update - Lots more work going on the bike!
OCS (Oil Containment Separator Fix) Rear swing-arm grease Chain maintenance Front sprocket relocate New rear shock install Digital gauge upgrade Backlog: Front wheel bearings seized... replacing bearings. If you start to hear squealing noise watch out! The front axle grease I put on during assembly are already dried up.. Change hazard switch to kill switch Upgrade kickstand Upgrade shifter
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 Last edited by AresROC; 09-27-2019 at 01:08 PM. |
#59 |
Kickstand Mod - Height Increase
Rear shock is now lengthened from 305mm to 320mm in the upgrade, so bike height have risen by ~1-1/2 inch. To compensate for the lean angle because the kickstand is now short, I found a piece of hardware that may offer a temporary solution
![]() It was as simple as tapping a M6x1.0 threaded hole on the bottom of the kickstand and screw it in. The current kickstand is 13-1/2" tall, so I need to find a 15" kickstand. If this mod works well enough I might just weld it on... TBD.
#60 |
Digital Gauge Upgrade
Ordered the digital gauge from site sponsor Tako aka NzBrakeLathes and it delivered in a week! I mapped out the Bashan BSR's harnesses with Tako and it is identical to a Bashan Brozz. The wheel speed sensor also fit perfectly!
Installation was a breeze. It was basically reconnecting the cluster wire 9-pin, and gear indicator 6-pin, plus power to battery. I added the rpm Blue/White wire with supplied pin and my crimp tool to the 9-pin connector, and it was done. Thanks to Tako's clear documentation, setup was a breeze too! Only exception was my wheel speed sensor had only 2 magnets, not 4 as stated in the doc. With accurate MPH and now RPM info, I will be able to tune my carb better. Plus no more annoying wheel speed wire that was being caught on the horn. I really wish I had done this upgrade much sooner! ![]()
