#46 |
No 5 is alive!?
Just cold. ![]() |
#47 |
http://www.dirtbikemods.com/mini_bik...ng_advance.php
would something like this work?? I really want to try this |
#48 | |
I helped a freind adjust the timing on his Honda Rebel, it was almost exactly the same as my Lifan. BTW, after I reset my timing, I got the bright idea to drill out the muffler. Actually, I think I lost some power when I did it, even with enrichening the mixture. Cliff Notes Version: Bumping up the timing works well for more power but to get any real benefit higher gearing is needed. |
#49 |
do you have the overhead cam or the pushrod?
#50 |
Did you take any pics of the timing change? Did you just file out the holes on the pick up about 3mm and tighten it up again in the new advanced position? Did you do anything to the fly wheel? Are you still able to wheelie the bike like you did when you sheared the key? What valve/ tappet noise are you talking about? Is it "pinking"? Is it valve bounce? Would harder springs make any difference? Does the seem much hotter after a ride.
Would you recommend doing the mod to the 163FML or 169FML? (which one do you have?) |
#51 |
I have a dinner plate of a rear sprocket, and I have tons of hills in my area, so I think I can really benefit from this. (there is a hill, and going up it I want to say the rpms are at around 1K, its that steep)
how do you go about removing the cover off the left side? (I dont want to undo any bolts I dont have to) |
#52 | |
#53 | |
Yeah, it still wheelies pretty good, but after I drilled the exhaust it seemed to loose a bit of grunt in the bottom half of the RPM range. The tapping sound I'm still not sure about, I'd bet it's in the valve train but exactly what it is is anyone's guess(if it had hydraulic lifters I'd say they had been floated, but it doesn't). I'm not taking the chance on killing the engine, so I won't rev it that high any more. I'd didn't seem abnormally hot, but it might have been running lean. After it cooled (cool to the touch) and was restarted, it sounded normal. |
#54 | |
#55 |
Hey guys, it's been a while. Has anyone else tried this mod yet? I'm anxious to give it a shot. Anybody else get the same results?
#56 | |
#57 |
Does a timing change like this affect the setting of your carb?
#58 |
It might increase your idle speed. Be aware it may alsoincrease the motor's operating temp as well. Head temp tends to increase with advanced timing.
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy ![]() Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
#59 |
The more advance you have, the more fuel you need, but only to a point. Fuel tends to cool the combustion chamber, a lean (or one with too much timing) engine pings due to the heat not getting carried away (think of that that little bit of gasoline acting like a fine spray of cool water, quenching the heat within the chamber.... that's exactly how it works).
That said, there's a point where the timing cannot be advanced any further, not matter how rich you're running. The optimum air/fuel ratio ( called the stoichiometric mixture) ranges from something like 14: to 16:1. Too lean and the engine pings (pre-detonation.. bad news!), too rich and engine damage can happen because the extra gasoline breaks down the thin film of oil between the rings and cylinder. (One you get the mixture just right, the engine (any engine) will come alive, but that really takes a wideband O2 sensor and they cost as much as a new China bike!) The sort version, if you have SLIGHT pinging you can richen the mixture some, if you do and it still pings, back the timing down a little at a time untill it stops. Pinging will always be at it's worst under load... WOT and/or uphill. |
#60 |
Well, I'm still only a few months into my motorcycling experience. Much to learn. But today I was installing new clutch plates and so I decided to try this timing advance trick. I followed the instructions from the free dirt-bike mods website posted earlier. Below is a picture of what my 200cc Roketa enduro looked like apart and the second shows the two places where I ground the holes. There wasn't much extra room to play with but I probably got it slid down about 2mm. Was down the correct direction to go? Just to clarify. I filed the top of the two bolt holes so that I could slide the sensor/pickup/whateveryoucallit down about 2mm. I then reassembled and rode. I can't tell much of a difference. Maybe a little more low end power? Nothing on the top speed. My exhaust has already been drilled. Perhaps someone can double-check to make sure I did this right. I hope I advanced the timing instead of retarding it.
