Old 10-31-2016, 01:00 AM   #46
95C1500   95C1500 is offline
Originally Posted by GeneralTso View Post
Bike looks good man, like that color choice.
Thanks!
Okay, so since I got it, I've thought the choke when UP: off MIDDLE: half and DOWN: full choke. Apparently it's the other way. Is that correct?
That means that my bike will cold start with the choke off, run with the choke off and after half throttle, it will not bog down I believe. I'll have to take it for another ride tomorrow to verify this. This is the way it sould function, correct?
Previously I was thinking that it would start and idle with the choke on, die at half or choke off. So I thought it was bogging down after half throttle with the choke on. If what I'm thinking is correct, since I had the choke reversed in my mind, my bike is running normally. Again, I'll have to test it out tomorrow to be sure. Didn't have a chance to ride it after I figured out I had backwards
I know my way around engines, carbs, etc... better than is this post is letting on. I'm tired and just want someone who knows 100% what they're talking about to verify this lol. So if the bike starts cold, idles, and doesn't bog throughout the rpm range with the choke off (all the way down), then it is functioning normally?
Old 10-31-2016, 01:18 AM   #47
Originally Posted by 95C1500 View Post
Thanks!
Down choke off, up is on. My problem is sometime not remembering to turn the fuel cock on
Southds like it's gona fly tomorrow if it can breath.
Old 10-31-2016, 01:37 AM   #48
My God I feel stupid lol. I was in the shop for an hour removing the carb, tweaking the mixture screw, reinstalling and testing only to find out I had it backwards and none of it was necessary lol.
I've forgotten the gas and the killswitch a time or two lol
Old 10-31-2016, 06:40 PM   #49
pistolclass's Avatar
2nd opinion.....
Lever up = Choke on
Lever middle = half choke
Lever down = No Choke
Do you live in a warm climate? Choke is only need on my hawk when the temp is 50 or less. ( that is Fahrenheit for all our metric friends)
Old 10-31-2016, 10:25 PM   #50
Originally Posted by pistolclass View Post
2nd opinion.....
Lever up = Choke on
I live in Texas. It barely gets below 50. It's almost november 1st and we had an 86 degree high today
Old 11-04-2016, 08:12 AM   #51
Typical South Louisiana weather lol. Wear shorts for Christmas. Bikes looking great. I like doing projects like that.
2004 Honda ST 1300
Old 11-05-2016, 06:06 PM   #52
Yes! Shorts at christmas time and during the summmer, even shorts are too much clothing lol
Old 11-05-2016, 06:17 PM   #53
Okay guys, I made a carb disassembly and tuning video which you can find here for the stock carb. Motocheez made a similar one but I didn't fully understand what was going on and what needed to be done so I decided to dive in and make an actual disassembly video myself.
I met up with another Hawk 250 owner from youtube today. We did a valve clearance adjustment on his bike and tweaked the carbs on both of our bikes then went for a ride. I'll have a video up of that soon too
Old 11-05-2016, 10:28 PM   #54
Merlin   Merlin is offline
Thanks for the helpful video. Looks like the same carb as mine.
Old 11-06-2016, 12:26 AM   #55
I'm glad you found it helpful
Old 11-07-2016, 11:02 PM   #56
Here's the video
Old 11-09-2016, 09:59 PM   #57
The rear sprocket on the Hawk, my friend is having problems with his and he was wondering why these just fall out. Are they supposed ot be welded in and someone along the line forgot to or is here an actual reason why these are loose like this?
Old 11-09-2016, 11:44 PM   #58
No thats how there made. I have the same setup with my steel wheel. The snap ring holds the sprocket in place and those pins prevent the sprocket from spinning. My aluminum wheel has bolts instead of the pins but still has the snap ring.
Old 11-10-2016, 03:03 AM   #59
My friend is wanting to have them welded in. Any problem with that? Or best to leave it alone?
Old 11-10-2016, 08:53 AM   #60
Ya just leave it its the way it was made to work.
