Old 06-20-2016, 12:30 PM   #46
Landsvw   Landsvw is offline
Landsvw's Avatar
Does anyone have a Honda rebel, cmx, or something similar they could measure the tank opening width, and the gas cap dimensions? Also, does the rebel use a vented cap? Some do some don't, I'm reading on the interweb... I can always drill holes, lol.
1988 Kawasaki KLR250
1969 Honda Z50 silver tag
2002 Ford F-350 7.3 diesel
1975 Corvette
2017 Chevy Bolt
“Throttle twisting geek” -LFN
Old 06-20-2016, 12:58 PM   #47
Landsvw's Avatar
I kept searching and found the measurements. UK eBay cap.
1975 Corvette
2017 Chevy Bolt
Old 06-20-2016, 01:00 PM   #48
Landsvw's Avatar
And, if it's a non vented cap, can easily be vented with drilling a hole in the bottom. Learned that today too. Some California Rebels have a charcoal canister attached, and a non vented cap.
1975 Corvette
2017 Chevy Bolt
Old 06-20-2016, 01:05 PM   #49
Originally Posted by Landsvw View Post
Who knows what frame my Roteka is modified from, but we know the engine is the Honda CG200.
I see you're in Abbotsford BC. I've been through there a lot. I lived in Alaska for 28 years (until I moved to Oregon to thaw) and usually turned south at Abbotsford to hit the custom station when I drove down the Alcan highway. Nice area. If I could move to anywhere in the world it would be BC. Love that pretty province. I'd move to somewhere probably out along the coast, or up between Smithers and Prince Rupert.
I can likely answer that. I bet your Roketa frame is just like mine, which is patterned after an early '80's XR200 (not the R version). Our Chinese friends welded a tube above the upper rear motor mount and used that for a monoshock mount. As well, they welded a bracket on the frame at the bottom to accept the linkage. On mine, the original upper twin shock mounts are still there, although they are used as rack mounts. My Lifan frame is almost identical, except the mounts are not there.
I did a comparison between the two frames here: http://www.chinariders.net/showthread.php?t=12613
I love Abbotsford. I often walk across the border at Sumas to pick up packages that I've had shipped there; it's very convenient. My wife and I are also in love with Oregon, and we visit as often as we can. We're planning to do more camping in the area and we might bring quads or bikes along.
Old 06-20-2016, 01:21 PM   #50
I was wrong about your frame. I went back and looked at the first page of this thread, and yours is quite different from mine.
Old 06-20-2016, 01:26 PM   #51
Landsvw's Avatar
If you come down this way, please contact me and we can go riding. I'm only a mile off I-5. And about 90 miles from the coast. But, my back yard is 1000's of miles of logging and mining roads. We can go all day, and probably even run out of gas if we're not careful! 😊😊😊 my XRL has the Exxon Valdez gas tank, tho, just for that kind of expedition.
Yeah, I'm still really curious as to what frame I have. It's very peculiar.
1975 Corvette
2017 Chevy Bolt
Old 06-20-2016, 01:27 PM   #52
Here's my Roketa stuff:
Old 06-20-2016, 01:28 PM   #53
I took those pics in the darkness of the shed, but I think the opening is just about a perfect 1.5".
Old 06-20-2016, 01:37 PM   #54
Landsvw's Avatar
Oh wow, that is very close to my cap. How would I go about searching for that specific cap type? I've spend a lot of time on eBay and can't find much similar except for that Honda rebel cap.
1975 Corvette
2017 Chevy Bolt
Old 06-20-2016, 01:48 PM   #55
Landsvw's Avatar
So, that's a plastic tank, but the cap goes straight down and latches, then the top turns to pull in the latches and release the cap. Is that correct? That is exactly what mine does. It does not do any quarter turns or anything inside the tank.
1975 Corvette
2017 Chevy Bolt
Old 06-20-2016, 03:22 PM   #56
The cap doesn't rotate at all; it simply pushes down to latch, and the key is turned to unlatch it. I'm not sure how to search for it (although I bet Humanbeing can find it - he's amazing). Keep your searches totally generic, like "dirt bike gas cap", "dirt bike fuel cap" or "dirt bike tank cap." I bet you'll find it eventually.
Old 06-20-2016, 08:42 PM   #57
Landsvw's Avatar
Took Roketa out on a 50 mile ride this afternoon. Went up a bunch of logging roads as well as street. Ran well. No real problems at all. The front brakes got kinda 'catchy' for lack of a better word, inside the master cylinder, but never failed. I'd say the suspension, especially the rear, is really not very good. Not as bad as old 2 shockers, but a bump causes it to rebound and then lose traction for a split second.
On the gas cap side of things, I finally found some bikes that have a similar cap, but nothing definitive yet. Certainly can't order 500 of them lol...
And, Hongdou Urban, and Travelon 150 seem to have the cap. Still can't find a cheap replacement tho... ��
1975 Corvette
2017 Chevy Bolt
Old 06-21-2016, 10:11 AM   #58
Landsvw's Avatar
Ok, found one on Aliexpress for 12-15$. Is that a legitimate site? Never heard of or used them before.
1975 Corvette
2017 Chevy Bolt
Old 06-21-2016, 07:58 PM   #59
Landsvw's Avatar
Here they are. I rode XRL 80 miles today. Hard to compare. Roketa is slower and bumpier. But definitely easier to handle due to weight and height. I love riding XR100 size bikes around, it's really fun, so roketa kind of fits that bill. Anyway, I changed fork oil and messed with the front brake. Still no answer as to why it's so sticky. Probably the rubber pieces are disintegrating. Oh well, still stopping it, just not as smooth as I'd like.
1975 Corvette
2017 Chevy Bolt
Old 06-22-2016, 02:18 PM   #60
Landsvw's Avatar
Fuel cap issue solved! For future reference, if you have need of a fuel cap, go to Napa and look in the back of their catalog. 11.99$ locking Stant or maybe Balkamp, cap. Vented. Works and fits like a charm.
1975 Corvette
2017 Chevy Bolt
