#46 | |
oil cooler
#47 | |
I doubt that there is a Hawk-specific cooler. The cooler is designed for the engine, not the bike. I've seen the banjo fittings in two different configurations at the valve cover, so you'd need to examine your bike to determine the best fit. Whichever cooler you choose will require at least some ingenuity on your part.
#48 |
BTW, use Google Chrome to view the cooler on Taobao. Chrome will translate for you. Sorta.
#49 |
Wolftrax, when you have time, please show us the air cleaner.
#50 |
Will do
Mark 2015 Haosen Hawk 250 2014 CRF250L 2014 CB500X Rally Raid |
#51 | |
http://www.banggood.com/Oil-Cooler-C..._content=73669
#52 |
cooler
i assume the cg150 cover shown is NOT the same dimensions as the one on the 229 hawk. lol
#53 |
Fairly good design, easy access about a 10 minute job. One glaring problem is going to be where the intake goes into the airbox. Looks like they didn't have a good fit out of the parts bin so they just stuck it in and lathered a bunch of silicone to seal it. Pod filter to the rescue. It really is to bad they didn't get this right because the oem filter can easily be retrofitted with a DIY foam filter.
Mark 2015 Haosen Hawk 250 2014 CRF250L 2014 CB500X Rally Raid Last edited by Wolftrax; 02-05-2016 at 07:20 PM. |
#54 |
Todays progress was slow, lots of lefty loosey, locktite, righty tighty! Tomorrow lube the rear suspension, adjust chain, check valves, dielectric grease on all connections, tidy up the wiring, install lights and maybe fire it up. But in the mean time I just couldn't resist dooing a quick luggage mock up and couldn't be happier with the Mosko Moto bags. They fit like they were made for the Hawk. Low and forward, perfect
#55 |
This is turning out to be a really nice looking bike.
#56 |
What did u do with the front fender?
#57 |
haven't even unwrapped it yet
#58 |
Well its alive. Did a couple of heat cycles Saturday. Got it all buttoned up today and did a Motoman hard break in, changed the oil a 20 miles and put another 100 mikes on her. Cruses quite comfortably at 55mph. Was very pleased with the comfort and road manners. It's no rocket ship but pulls steadily in all gears. Going to put 500 miles on her and a couple of more oil changes before is swap carbs and mess with the gearing.
As a sidebar, check your valve clearance during assembly. My intake was .000 and my exhaust was .025.
#59 |
Homemade "oil cooler" from old parts http://www.motorfans.com.cn/bbs/view...d=75082&page=1
Raditor : Honda CH125 Spacy ...
#60 | |
