Old 01-08-2016, 02:22 PM   #46
rjmorel   rjmorel is offline
rjmorel's Avatar
I think for the riding you do Willydog, the 13t would be a big improvement. I tried it and still rode down the interstate all day long at the 65mph speed limit. MPG went south to middle 50's. But the 13t really made a difference when going on gravel fire roads and up hills. I switched back to 14T when knowing I'll be on the highway lots. rj
Live Zong, and Prosper
Old 01-08-2016, 02:36 PM   #47
willy dog   willy dog is offline
willy dog's Avatar
thank you found answer on early posts think i will start out with 13ft and 44 r see how that works thanks again
Old 01-08-2016, 03:15 PM   #48
As usual, Rob gave you good advice. I think you will enjoy the 13T/44T sprocket combination.
Old 01-08-2016, 03:58 PM   #49
RedHawk47   RedHawk47 is offline
RedHawk47's Avatar
One thing missing from the chain adjustment instructions:
Put the transmission in neutral while adjusting the chain. If you don't do this you may have some slack in the upper run which would mess up your true chain tension.
Dan
CSC RX3 Cyclone, CSC TT250, Moto Guzzi V7 II, KLR650
Old 01-08-2016, 05:20 PM   #50
rjmorel's Avatar
Good advice Redhawk47, never even thought about that little detail, rj
Old 01-10-2016, 11:57 PM   #51
Good thinking!
Old 07-04-2019, 01:04 PM   #52
Gaijin   Gaijin is offline
Originally Posted by detours View Post
Tools Needed
  • 8mm socket - countershaft sprocket cover bolts
  • 13mm socket - outside axle locknut
  • 13mm open ended wrench - inside axle locknut
  • 18mm socket - left side axle bolt
  • 19mm socket - right side axle nut
  • 30mm socket - countershaft sprocket nut
  • Large flat blade screwdriver - countershaft sprocket safety washer
This is a fantastic tutorial, thanks for taking the time to write it up!
One thing I have to point out -- this was apparently written for earlier models; on my 2018 the countershaft sprocket nut requires a 32mm socket.
Old 07-04-2019, 04:32 PM   #53
dannybiker   dannybiker is offline
Higher gearing?
Has anyone raised the gearing? There's lots of talk about lower gearing for off road riding and I totally get this, but I'm not sure if I can stand the high revs all the time on the road for ever.
Keeping up with the traffic sees my bike living around 7500 and this is tiring and noisy. I can redline the bike in top on any flattish road and so wondered if it was feasible to replace the rear sprocket with something smaller thereby raising the gearing and making the whole thing a bit less frantic.
I'd appreciate your thoughts
Old 07-04-2019, 05:36 PM   #54
Well, you can certainly do exactly that. CSC sells rear sprockets in a variety of sizes, from 42 to 46 teeth. Dropping to 42 teeth should lower your RPMs by almost 5% at any given speed.
Old 07-05-2019, 12:54 AM   #55
The lower gearing is for road riding. I almost never go off road. The bike is much more rideable on the highway with the 13t sprocket. The choice is between holding high RPM or losing speed all the time because the motor can't pull the gearing.
Old 07-05-2019, 01:46 PM   #56
rjmorel's Avatar
So I geared mine up when I rode the Iron Butt 1000 I did a few years back. Totally worthless on the roads I rode because to many hills and wind. Oregon, Idaho. I was always downshifting into 4th or 5th to get over hills or get out of traffics way. I think I went down 2 teeth on the rear sprocket.
On level ground it may be OK . Stock 6th gear is almost overdrive and I found the stock RX3 geared about as high as I would want to go IN MY NECK OF THE WOODS. YMMV
If someone needs a rear sprocket to gear it up and give it a try...……..hows $5 plus shipping? I think it's a 42T but would need to dig it out and confirm. rj
Old 11-10-2019, 10:54 AM   #57
ddilink   ddilink is offline
I looked everywhere to find the proper chain tension. Not in the owner's manual. Finally found it here. Thanks.
