Old 12-25-2015, 03:54 AM   #46
Good for you, Sprite. The next time you will complete the job much faster, since you are now more familiar with the entire procedure.
Old 12-25-2015, 01:35 PM   #47
Lee R   Lee R is offline
Lee R's Avatar
I find a soda straw in the spark plug hole works really well to judge what stroke your on as well, you can see it rise all the way to the top on compression and you know your at TDC. Get the flexible end type and bend the top at an angle to prevent it from falling all the way in. The rocker arms should "wiggle" a small amount when you rock them side to side. This is how I check the Guzzi valves without pulling all the rubber plugs to find the index mark.
Shifting to a high gear and using the rear wheel (on a stand) also makes it easy to cycle through strokes.
The timing marks also look like a good technique.
Here's a good video of how each stroke works for those who are curious or don't know already.
Old 12-25-2015, 05:57 PM   #48
I say this with all respect: Atta girl, Sprite! Good for you for jumping in and taking care of it.
Old 12-25-2015, 09:36 PM   #49
AZRider   AZRider is offline
Way to go Sprite. And for future reference, I'm retired and have plenty of time on my hands, so would be happy to help any time you have the need.
George
2016 CanAm Spyder F3-L
Old 04-17-2016, 05:04 PM   #50
willy dog   willy dog is offline
willy dog's Avatar
adj. valves yesterday all went well, took the zong out for 130 miles valve cover on exhaust side was leaking. always carry spare oil got it home o ring looked fine nothing loose cleaned everything up again this time put thin layer of permitex any body else had this problem?
Peace and Zong Life
Old 04-17-2016, 05:18 PM   #51
Inroads   Inroads is offline
One of my intakes was leaking turns out you can install upside down.
Old 04-17-2016, 05:45 PM   #52
rjmorel   rjmorel is offline
rjmorel's Avatar
And you can't swap intake cover for exhaust cover if memory serves me right. I marked mine before I took them off the first time, always put them back on according to that and they have never leaked. rj
Live Zong, and Prosper
Old 04-17-2016, 05:54 PM   #53
willy dog's Avatar
i knew intake and exhaust were diff. i know i got that right did not know could install upside down, it is right now don't no how it was when leaking thank you all
Peace and Zong Life
Old 04-17-2016, 09:33 PM   #54
In addition, eventually the O-rings will harden, leak oil, and need to be replaced.
http://www.cscmotorcycles.com/PART-2...-p/z10-101.htm
Old 04-18-2016, 01:03 AM   #55
detours   detours is offline
detours's Avatar
I thought both valve covers were identical, but I guess not. They definitely can be installed upside down. The bolt holes are oriented different on each side.
http://www.aliexpress.com/item/32635...Id=32635978824
Red 5 standing by!
2014 Ural Patrol
Old 04-18-2016, 05:08 PM   #56
dave92029   dave92029 is offline
No adjustment required
How many have found that their valves were unchanged from their previous adjustment? No adjustment required.
Dave
Old 04-18-2016, 06:55 PM   #57
With 14,000 miles on the odometer, I have adjusted the valve lash about six times. Perhaps once the valve lash was unchanged from the previous adjustment. That's why I check the valve lash every 2,500 miles, as originally specified by CSC.
Old 06-03-2016, 03:57 PM   #58
willy dog's Avatar
doing 2nd valve adj. as i type when i pulled plug wire and plug noticed end of plug has threaded part no little cap that threads on is that normal or did i lose the cap on the plug
Peace and Zong Life
Old 06-03-2016, 04:00 PM   #59
detours's Avatar
That's normal. There is no smooth cap on our plugs. It just sits on the threads.
Red 5 standing by!
2014 Ural Patrol
Old 06-03-2016, 04:13 PM   #60
willy dog's Avatar
thank you detours once again you save the day on a side note checked valves at 500miles did not need adj now at around 1800miles still not tight not really winding it up much past 8000rpms should i wait till 2500miles and check again it runs great
Peace and Zong Life
