Old 08-25-2014, 01:14 AM   #46
I don't really understand how reserve works with that style of petcock. The petcocks that I'm familiar with have two tubes, with the shorter being the reserve. How does it work with only one tube?
Good thinking on the cap. Please show us a pic of the existing cap. BTW, you might be able to flush some junk out with carb cleaner and compressed air.
Old 08-25-2014, 01:45 AM   #47
Dave_D   Dave_D is offline
Dave_D's Avatar
This us just an image I found on Google. But petcock I used works the same way
"On" draws fuel from the tube. And "reserve" from the opening left around the tube
The strainer covers it all aswell
I'll get a couple pics of the cap tomorrow top and bottom.
I'll probably tryed compressed air and carb cleaner though.
Thanks
Dave
Old 08-25-2014, 02:29 AM   #48
Interesting. So, the entire length of the tub is the reserve amount. Thanks for the explanation.
Old 08-25-2014, 10:27 AM   #49
Dave_D's Avatar
Managed to grab a couple pics before heading to work today.
Top view
Bottom
Dave
Old 08-25-2014, 10:53 AM   #50
I haven't tried to dismantle that style of cap. Try the brake clean and compressor idea first, and see if that solves it. If not, you can likely take it apart and clean the spring, ball and seat.
Old 08-25-2014, 11:52 AM   #51
Dave_D's Avatar
Yea. I'll see what I can do lol.
To go further into detail on the reserve topic
Having 2 tubes is bennificual vs this style. This style will suck up anything that collects in the bottom of the tank.
Having second tube will collect above the sludge. Rust. Ect
Dave
Old 08-25-2014, 03:26 PM   #52
As an added benefit of the two-tube style, the tubes often have screens to prevent exactly what you're saying.
Old 08-26-2014, 06:14 PM   #53
Dave_D's Avatar
Continued from another thread. Also at the post office was this funny looking box
The contents
Here it is next to the "original"
I'm bringing it all to work tomorrow to make the required modifications.
But this is going to work out great
Thanks again weldangrind.
Update on the gas cap. Had no issues today and we rod for quite a while
Dave
Old 08-27-2014, 01:02 AM   #54
Happy to help. I'm surprised it made it there that quickly. It looks like you already had a bolt for it.
Glad to hear that Jess' gas cap is working.
Old 08-27-2014, 01:08 AM   #55
Dave_D's Avatar
The bolt I used for version 1 was the same thread as this stand. Will work good
Should have updates tomorrow
Dave
Old 08-27-2014, 01:22 AM   #56
Cut the kickstand to the desired length, then weld a nice big foot on it.
Old 08-27-2014, 11:28 PM   #57
Dave_D's Avatar
Here it is guys
Probably more pictures then required. But oh well lol
Here's what I started with (thanks to weldangrind )
I started by cutting the spring tab off as it needs to be moved to the opposite side
I scribed a line down the length of the shaft so I could line it back up after cutting as the foot is perfect
Here it is in the band saw at work
Cutting
I cut 3 1/2 inches out of the length. I figured this way was easier then trying to cut the weld at the foot and recreate the angle
I ground a pretty good bevel onto both pieces. I did this cause I knew I was going to grind most of the weld away to clean things up
Line my marks up for welding and tack it
Terrible picture. But welded all the way around
Now I welded the tab back on. I'm still not used to the welders at work. But it'll hold. I use a hobby grade flux core mig at home. Works great. Our shop at work is divided into 2 wood shop and metal shop. I work in the wood shop. It's nice having both at my disposal lol
Here's the kickstand before grinding the welds smooth and cleaning it up
Here it is with the weld ground smooth. And what's left of the weld from where the tab was originally
I finished cleaning it up and sprayed a quick coat of paint
Here is version 1 next to version 2
I got home and was excited to get it installed. Went smooth as butter.
Here it is on the stand. It is much much more stable them version 1
It also looks a million times better then version 1
Thanks for all your help everyone
I think the seat is next on the agenda for this project as it's an eyesore
Dave
Old 08-28-2014, 01:44 AM   #58
Nice work, as always.
Old 08-28-2014, 11:05 AM   #59
I'm surprised! I thought that kickstand was bent, but it seems to have the perfect angle to suit the chain and swingarm. Nice job.
If you can't get on the seat right away, at least substitute the duct tape for Gorilla Tape. It's much stronger, and it's black.
Old 08-28-2014, 11:23 AM   #60
Dave_D's Avatar
I tryed it first to see what the bend looked like
As I wanted to add some angle to version 2 anyways to make it more stable.
I'll get a top view with kickstand up tonight it barely sticks out the side
Dave
