Old 02-19-2013, 11:43 PM   #46
Yeah, but that will be displacement or oil volume, depending on the number.
Old 02-20-2013, 01:45 AM   #47
migue1760   migue1760 is offline
migue1760's Avatar
My model number is 163ML with like more digits, nd the diplacement is 197
Old 02-20-2013, 10:03 AM   #48
163ML broken down:
1 - one cylinder
63 - 63mm bore diameter
M - motorcycle
L - 200cc (this number is normally rounded up; as you say, yours is actually 197cc)
Old 02-21-2013, 12:57 AM   #49
migue1760's Avatar
Ohh thank you, so there is no actual manufacturer for my engine?
Old 02-21-2013, 09:51 AM   #50
There might be a decal on the steering neck that states the atv manufacturer name, but that isn't necessarily who built the engine. It doesn't really matter, because several of the engines will have whatever name the importer requested.
Old 02-21-2013, 05:13 PM   #51
migue1760's Avatar
Ohh, thanks for the info whats the screw on the right and bottom of the carburator
Old 02-21-2013, 05:15 PM   #52
migue1760's Avatar
And the company is CHONGQING HUANGSONG INDUSTRIES GROUP CO.LTD but they dont have any diagrams on the engine
Old 02-21-2013, 10:06 PM   #53
migue1760's Avatar
Off topic but can the little clutch move a 350 pound buggy fast?
Old 02-22-2013, 12:33 AM   #54
Define fast. You could probably get 50km/h or 30mph if you really pushed it.
Old 02-22-2013, 12:34 AM   #55
The screw on the right is the idle screw. The screw on the bottom is the pilot mixture screw, and it tunes the transition from idle to open throttle. It should be adjusted so that there is no lag when the throttle is opened quickly.
Old 02-22-2013, 12:41 AM   #56
migue1760's Avatar
So with the 7.5 hp briggs i could go around 25? With the centrifugal clutch, and for the idle screw i move it and the engine keeps running normal, is it the air mixture?, and it does lag when i engage the throttle quickly
Old 02-22-2013, 12:51 AM   #57
A new carb will help quite a bit, because a Mikuni is much easier to find jets for.
The idle should definitely increase as you turn the idle screw in.
Old 02-22-2013, 01:17 AM   #58
migue1760's Avatar
Is my carb a mikuni?, we it has an idle type of thing on the throttle cable
Old 02-22-2013, 10:01 AM   #59
Are we still talking about your atv? If so, then no, I think your carb is a Keihin clone. A 30mm Mikuni is much easier to find jets for.
BTW, it would be great if you started another thread in the Miscellaneous section for your go-kart / dune buggy. I'd like to see more of it without distracting this thread.
Old 02-22-2013, 11:28 PM   #60
migue1760's Avatar
Im goint to try to get one, and the battery in my atv heated up the ground wire and melted it :x ill post another thread of the buggy
