#46 | |
![]() Incidentally, I will restate, this was a Yamaha rocker which came inside the XT200 cylinder head I installed. ![]() Spud ![]()
#47 |
Here's a photograph of my valve spring compressor which I bought on eBay for a very reasonable price.
![]() ![]() With the cylinder head removed, here's how you attach the tool to compress the valve springs, and remove the valves. For illustrative purposes, I have the tool attached to a 1982, XT250 cylinder head. ![]() ![]() One end of the tool is centered on the bottom of the valve. ![]() The other end of the tool compresses the valve spring as the handle is turned. The open adapter on this end of the tool allows you to remove, and install the valve retainers more easily. ![]() I have removed the valve rockers as well as the camshaft from this cylinder head, so I have a lot of room to work. ![]() ![]() You must remove the camshaft, or you won't be able to compress the valve springs. However, you can use the tool with the valve rockers installed, as shown below. However, you have less room to access the valve retainers. ![]() ![]() After the valve springs are compressed sufficiently, I use a magnet to remove the valve retainers, as shown in the following video. ![]() I prefer to lap the valves using a short section of hose connected to the valve stem with a small hose clamp. ![]() ![]() ![]() Here's a closeup view of my valve lapping tool attached to the valve stem. ![]() ![]() Spud ![]()
#48 |
I changed the engine oil approximately 500 miles after my engine rebuild. The oil filter was a little dirtier than usual. I also cleaned some tiny, metal specks which were deposited in the oil filter cavity. However, nothing was unusual in this regard.
![]() ![]() Here are several photographs I took during today's ride. ![]() ![]() ![]() ![]() ![]() Spud ![]()
#49 |
Was your bike using much oil before the rebuild?
#50 | |
![]() Spud ![]()
#51 |
Thanks again for the pics Spud. You put a lot of work into this project and researching how to do it. We all appreciate your sharing with us. The Zong is a GREAT trailbike and deserves the work you have put into it. We Chinariders should have bought a container of them when they were under a grand delivered! :wink:
Happy to serve. |
#52 |
Thank you, Doc.
#53 |
Your Zong looks great, Spud. I'm glad that we were all able to watch as you slowly changed it into what it is.
Do you still have the old cylinder? What does your machinist think the outer limits would be? It would be interesting to learn if you could gain more cc's by boring and choosing a Wiseco piston.
#54 | |
![]() ![]() I have the original cylinder, bored to 4th oversize, which is +1.00 mm. I can't find an appropriate Wisceo piston which is larger. However, my Zongshen 210 is running stronger than ever with the addition 6cc of engine displacement from the two cylinder borings. ![]() ![]() Spud ![]()
#55 |
How much longer do you think the weather will allow you to ride at that altitude, Spud?
We're cooling off here. Highs still in the 80s but getting dangerously close to the 30's at night. Winter is not worth living through... ![]()
Happy to serve. |
#56 |
That tells me that a TTR-230 (or similar) engine would have to give up its crank for larger displacment than what you have now. Would you do that, or just search for a complete 230 motor?
#57 | |
![]() Spud ![]()
#58 | |
#59 |
Removing the cylinder head and cylinder block
Spud,
The cylinder head and cylinder block are liking oil (small amount) and need to take them off. However, I tried but the 4 studs (2 attached in the left and 2 right crankcase that hold these cylinders) are impossible to remove. I check your thread posted in Sept 2012 about the engine rebuild and learned you remove the studs. The pic 3 you installed the cylinder block with no studs and wonder how you did it ![]()
Hector Mountrack Vento 2006 |
#60 | |
![]() ![]() ![]() http://www.cyclepartswarehouse.com/f...83&fveh=177068 You will need to replace both gaskets with new gaskets, or you will definitely have engine problems. ![]() ![]() http://www.cyclepartswarehouse.com/f...13&fveh=204271 http://www.cyclepartswarehouse.com/f...13&fveh=204271
