Old 06-17-2020, 02:07 PM   #46
Jsalmi   Jsalmi is offline
Hello,
I ordered this oil cooler from Alibaba been 6 weeks now, Ali"NOT SO"Express showing tracking in Atlanta. Maybe get it this week LOL
https://www.aliexpress.com/item/1974...7f5125131pPIMM
JT 1264.17 is the sprocket I put on my Xpect have 1350 miles on in now.
Old 06-17-2020, 07:35 PM   #47
bored stiff   bored stiff is offline
pics look great ,can you post link to where you got the hand guards ,thanks
Old 06-17-2020, 08:37 PM   #48
Wild Dog   Wild Dog is offline
Originally Posted by Jsalmi View Post
Hello,
Don't blame Aliexpress, it's mostly delays from either the seller or US Customs.
I will never get tired of saying this on the Netherlands Aliexpress is lighting fast. Due some deals with PostNL.
On Argentina is neither slooow nor Fast just average.
Plus Aliexpress backs their customers, some chinese sellers tried to rip me off with some Computer gamepads and i got my money back.
Old 06-17-2020, 10:11 PM   #49
NoirLord   NoirLord is offline
Did an Apache 3800 top box mod today! Wish it was a little taller but it’s not bad at all! I will be using dry bags for the rest of my camping/adventure gear but I wanted something secure for the daily commute. Also put another 50 miles on her today after lubing the chain. I think a fork oil change will be added to the list of mods I need to do next.
File Type: jpg 00E8C8EC-6C63-49EB-BA55-0F40F61FB5DD.jpg (19.8 KB, 1676 views)
File Type: jpg 0B152D97-72C4-48AB-AD92-9F838FE72343.jpg (19.7 KB, 1573 views)
File Type: jpg 5030C034-0209-42BD-A36C-35D629BB0DFC.jpg (19.9 KB, 1622 views)
Old 06-20-2020, 06:01 PM   #50
legonas   legonas is offline
i got my handguards on amazon. it takes some work to make them fit. you have to trim the grips down on both sides and move shit around to get it all to fit. make sure your throttle spins freely i had to cut my grip on the throttle side down a lot.
Old 06-20-2020, 07:12 PM   #51
Moongrass   Moongrass is offline
Moongrass's Avatar
Hello all,
Got my Expect 200 in late December from Orion Powersports. Had to send Mco back to have it signed with mileage stating 0 miles along with a FL odometer statement stating mileage reading 0 miles. Like the bike so far, ran a little rough at first. Of course I changed to oil before starting it to Actevo 10w40.
Then got a NGK iridium plug at Oreillys, much better. So before I was even tagged and ready to ride I had a JTF 1264.17 front sprocket delivered believe it or not from Walmart.com. I drove it for about 80 miles in two weeks this month and decided the rpms are a little high at 60mph (during break in, was a little nervous to exceed 8k rpms. This week I loosened the chain, pulled off the front sprocket cover and swapped it out with 17 tooth for the original 15 tooth. Little tight putting the cover back on, had to move the bike in gear to make it go on. But what a difference, big improvement in rpms going down the road at 50-55mph. Feels so much better cruising long distances. Will report actual rpms later as I ride on weekend. Anyways, here it is with new mirrors and a Givi 29L tail box.
I really like that top box. About to order this bike, does it need a special bracket or anything? Does the x Pect come with a cargo rack?
Old 06-20-2020, 11:37 PM   #52
LoneStarGazer   LoneStarGazer is offline
Maiden voyage...
Took my new X-Pect 200 out on the road today and it was a big hit with my neighbors! It seemed to be a bit high geared from what I’m used to, but that might just be me. I prefer granny gear in 1st.
Painted the fairings blue, added a manual chain lube, and installed a security alarm with remote that’s pretty cool (and LOUD, and it works!)
Next on my little bucket list are lower foot pegs and possibly an oil cooler, but it would be helpful if I knew what model Honda is the closest match. Is it the CG200 or another model?
Thanks!
File Type: jpg 22EA9053-B6F9-41BD-A575-57EBB21ACAD2.jpg (19.7 KB, 1779 views)
Old 06-21-2020, 01:53 PM   #53
Oil Cooler
Ok got it installed today first try no leaks, can feel a little heat coming on to my feet now when riding.
Old 06-21-2020, 05:10 PM   #54
Spins   Spins is offline
Spins's Avatar
Looks good!
I was looking at one of those. I now have it in my saved for later cart on Amazon.
2019 Z 400
2020 Tan Recon
2021 KLX 300
2022 GPX FSE 450R
Old 06-21-2020, 09:35 PM   #55
Jsalmi,
That’s the oil cooler you got from AliExpress, put on a X-pect 200, and it fit and works as you expected? The oil circulates well enough? If so, I’ll be ordering one of those soon. Thanks!
Old 06-22-2020, 04:31 AM   #56
looks great, how many miles on now?and are you having any issue with this ratle that so many are?
Old 06-22-2020, 06:03 AM   #57
Originally Posted by LoneStarGazer View Post
Jsalmi,
The cooler is from Aliexpress, took 6 weeks to get here from China. Its works great, I mounted it a little lower than most here have done. I has a rock guard/screen on the front of the cooler. Just turned 1400 miles on the bike
Old 06-22-2020, 06:31 AM   #58
No bracket required comes with mounting plate and bolts directly to idk if you can call it a rack on Xpect but it has 4 mounting bolts on the back after you remove the plastic piece.
Old 06-23-2020, 11:06 AM   #59
Thanks, I just ordered one as well...
Any install tips you could share?
How do you fill the system?
Thanks...
Old 06-23-2020, 02:28 PM   #60
Install Tips, well I just studied the pics of the product and the flow of the oil in the crankcase. Bottom hose out and top hose in, then in the filter canister the screen facing the same way as it was originally in the Lifan engine. The oil cooler comes with no instructions, just take it out piece it together and don't rush. Found that the sealing washers for the fittings are two different sizes. Big ones go on the cooler, small on the adapter. Comes with syringe to inject oil, I used it and then just engine at 2k rpm until I started getting heat in the cooler. It's a really nice looking unit for the price, I was expecting a lot less.
