#46 |
1st commute to work this morn
i wanted to mention that the gearbox and clutch are superb! it is smooth as glass in shifting up or down. neutral is easy to find. no noises, grinding, or rattling. i did find a void spot between 5th and 6th once but i blame that mostly on me babying it and not changing gears like a man. i cant remember where i read the main complaint was the gearbox, must have been a different yr model or different model all together bc this one is like glass! no sudden down-pull or jerking, it simply is glass-like, i don't think a passenger could even feel the shift.
the ONLY complaint i have so far(if i had to mention one) is the handlebars being just a bit too low for my 6'2" 200lb frame, and being 44yrs old, but its still not a deal breaker for me bc I LOVE THIS BIKE! there is no "i wish it had more power" to keep up with traffic on a 55mph highway, nor does it lack power to pass someone. buying one new is my spice of life bc i have found out that no one sells a good used bike around this price range, or very few far in between. its an all around excellent 250 class street bike! so far Last edited by imapdog; 08-29-2019 at 10:03 AM. |
#47 |
I think once you do the handle bar mod it will be the perfect bike.
#48 |
The GD250N must of never been imported into the US. I've searched everywhere and have not been able to locate one. Technically the only difference between the GD250R and GD250N is the lack of fairings and conventional handle bars. For the Price you picked up your bike the cost to covert it to GD250N handle bars is nothing. Even less if you do the free mod of relocating the existing bars above the triple tree.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 08-29-2019 at 11:40 AM. |
#49 |
Here's a picture that someone just flipped the triple tree top bridge.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 08-29-2019 at 03:07 PM. |
#50 |
yeah, i need to do this. i haven't found this hit. the ones i find dont flip the tree over, but this is something i want to study. what do they mean by 'caliper is needed'?
#51 |
I haven't figured that one out either. If you read the whole thing it sound like somebody is shooting some BS to make it seem complicated to give his buddy's shop some business. lol
How complicated can it be? lol He has a video I ran across of them actually doing it. I haven't be able to find it but will post it when I do.
#52 |
I searched through my YouTube history and could not find it then remembered it wasn't on YouTube where I found it but embedded on a website.
#53 |
forward control kit installed easily
i was skeptical of this making much of a difference. i was wrong and this does make a huge difference for taller riders. glad they included the kit. here is pics of the kit installed while removing the spacers and using shorter bolts. all included.
Attachment 18237 Attachment 18238 Attachment 18239 Last edited by imapdog; 02-14-2020 at 08:48 AM. |
#54 |
Yeah, you wouldn't think removing what looks like a 1" spacer would make a difference. At least they were thinking and making everything adjustable for different size riders.
![]() Did you get a chance to look at the handle bar adjustment?
#55 |
Did you get a chance to look at the handle bar adjustment?[/QUOTE]
I did look for a long time several times to find something as to how it was done in your shared pic. i give up trying to find forum or video on it. however i did look the bike over and it scares me. if i remove that main bolt in the center of the tree, what will happen? to me it seems as if the front end has to lower at least the thickness of the tree. will that make it handle awful? if you look at one of my pics below you can see where the rear shock can be adjusted, but i am uncertain it will lower enough to match the front lowered difference. i love the way this bike handles and paranoid doing this will hinder the performance. i am open to ideas clues or anything about this.....it would be perfect for me if i can be successful in the tree flip |
#56 |
The only video I have been able to find again was on the GT250R. The one with GD250r was done almost the same way except they flipped the top triple. From what I have read no one found any difference in handling.
#57 |
A little pricy but you could always get riser clip ons like these. Not sure the size of your fork tubes. Just have to find ones that will fit your forks. https://www.amazon.com/Woodcraft-Rac...3&s=automotive
#58 |
sure doesnt feel like a thumper
nice 30 min ride into work this morning hovering around 55-60mph most of the way. i have to say this engine does not thump like a typical single cyl or maybe its bc its just 250cc. irritating vibrations at 55mph are non-existent. hands/feet/body feel fine. the adjusted forward foot peg controls made huge difference. the seat is very comfy and can shift your cheeks around easily with plenty of room and options. the ONLY thing yet to figure out is flipping the triple tree over allowing top mount for the handlebars for higher grip. i love this bike
![]() ![]() Attachment 18283 Last edited by imapdog; 02-14-2020 at 08:48 AM. |
#59 | |
#60 | |
Attachment 18287 Attachment 18288 Last edited by imapdog; 02-14-2020 at 08:48 AM. |
