09-18-2016, 06:35 PM | #46 |
Okay cool. Stock is the 428-130 chain right?
09-18-2016, 06:48 PM | #47 |
I use the stock chain. I couldn't fit just the 17 front, the chain wasn't long enough.
09-18-2016, 06:51 PM | #48 |
Okay that's good. I planned to do both anyways. Now I just plan to do them both and a better chain at the same time
09-18-2016, 08:33 PM | #49 |
How was the chain not long enough? You went from a 15 50 stock to a 17 45?? +2 in front -5 in back. Math don't add up don't listen to this guy
09-18-2016, 09:53 PM | #51 |
I have 17/45 on the stock chain. My chain is new and unstretched, there wasn't enough forward travel for the rear axle to fit just the 17, as in 17/50. I have read others were able to fit 17 with stock 50 on the rear, but their chains had already stretched some.
Also, my front sprocket cover did not need cutting to fit the 17, I've seen others needed it cut. Mine did require finagling to fit, but once I figured out how to angle it in, it goes in and out easy. |
09-18-2016, 10:07 PM | #52 |
I'm sure everones Hawk responds a little different but my hawk out of the crate would have to keep the carb on full choke for 15-20 minutes until it was good and hot then I could move it to half choke then 5 minutes later move it to no choke. It wouldn't let me WOT until it was hot. I picked up a VM26 carb off ebay for $39 and a needle kit too. Mine likes the 110 main. I never got around to doing the pilot so my needle clip is at the bottom ( most rich ) setting. If I adjust the pilot I think I will be able to get that clip in the middle. I will fiddle with it later , but now it runs great. starts right up, idles nicely and WOT is fun. The entire throttle range is pretty sweet so I'm reluctant to tinker to get the coveted middle clip. ARH can probably chime in as to why I should work towards the middle clip, but for now I'm just enjoying the ride.
09-18-2016, 10:18 PM | #53 |
Mine wouldn't start without choke until I adjusted the valves, they were so tight I'm not sure they were even seating properly. After I sorted out the proper valve clearances, I had no trouble starting with no choke on a summer day.
I do need to get a new carb and exhaust, I can't run WOT, it bogs the last little bit. I probably have 80% useable throttle. |
09-19-2016, 08:58 AM | #54 | |
09-19-2016, 07:20 PM | #55 |
Agreed ARH. Totally different bike when the valves are properly adjusted. My Hawk prior to adjusting the valves was very difficult to start. Also it would not wind out very freely. If you can make only one adjustment to the hawk, it would have to be the valves. It is more important than CARB, Exhaust, CDI Spark plug and gears.
There should be a sticky here saying if you buy one before you start it, change the oil and adjust the valves. everything else is just nice to haves. |
09-19-2016, 08:40 PM | #56 |
Absolutely. Might even add change the oil twice, my second change still had a large amount of that sewing machine oil left in it.
09-23-2016, 12:16 AM | #57 |
Haven't forgotten about this place. School's keeping me busy. Still trying to find time in my schedule and the seller's to go look at another Hawk.
09-23-2016, 10:05 AM | #58 | |
10-06-2016, 01:11 AM | #59 | |
Sup Scott? Didn't realize you made your way over here as well! Wasn't sure if it was you till i seen pics of your 400.
Past bikes: '10 Gio X33 '85 Honda VF750F Interceptor '80 Honda XL185S '76 Yamaha DT250C dual sport Baja Wilderness Trail 250 '07 Honda Shadow 750 Areo Trike '01 Harley Davidson Softail Deuce Polaris Magnum 425 4x4 Quote:
10-12-2016, 04:06 PM | #60 |
Yep, its me haha. I'm all over the place
Going to look at a couple on saturday. I do have another question though. If I were to buy a bike that is already tagged, and when transferring the title to my name I decide to unregister it (is that the term?), what would I need in order to register it later on down the road? |
