#46 |
It looks great Doc! Would you like to do a front disc brake upgrade? I have some parts...
#47 |
The Rat is running great. I trail rode 40 miles this weekend without a hitch.
The seat cover I bought is wrong, will try to send it back. The chain and rear sprocket are shot. Since I'm leaning towards keeping it, I will order new ones. A Tsubaki and a JT, respectively. The front sprocket is new. Does anyone know if these Honda mufflers need to be repacked? It sounds kinda meaty.
Happy to serve. |
#48 |
ahh doc just swap that can out for a new fmf one, or hmf, dg, yoshi.. add some power, a nicer sound, and hotter looks
200cc beast replica,carsoli cdi,performance coil,fmf powercore 2,uni air filter,hour/tach meter,jetted mikuni carb,msr bars,moose racing grips,yz250f clutch perch,D.I.D chain |
#49 |
Holy Cow! I must have accidentally unsubscribed from this thread! 8O I'm glad I discovered the problem, and got back here!
![]() The "Dirt Rat" looks great, Doc! You did a superb job. ![]() Spud ![]()
#50 | |
Happy to serve. |
#51 | ||
![]() Spud ![]()
#52 |
Swapping on a different pipe is a challenge, since there isn't much aftermarket support for this model year. I don't think that the stock mufflers require packing, but maybe the baffle has been removed.
If you seriously want to swap the muffler for another product, let me know. I worked out a solution for Son of Weldangrind's '83, because the stock muffler was rotten.
#53 | |
Happy to serve. |
#54 |
im sure the header is good, i was merely talking about the silencer.. a nice fmf, dg or hmf silencer with a quit core inscert would look great..
if doc really really wanted a head pipe, just take it to any muffler shop who does customs exhaust for cars.. they have stainless steel pipe and the means to weld it..
#55 |
I plan to stick with the stock unit on mine. Our trails are within city limits and close to houses. I don't need to make any more noise than necessary and power is not really that important to me. Most likely won't get past 2nd or 3rd gear.
#56 | |
It's geared low, appropiate for a dirt only machine. I bet even at 20 on the trails you'll be in 4th or 5th. Should be quiet enough. I will check my baffle, and spark arrestor.
Happy to serve. |
#57 |
Maybe need a 14T sprocket then. I don't need to go too fast. The trails are short and twisty. Maybe a 4 acre area that we do laps on. The 90cc stays in 2-3rd most of the time.
#58 |
A 14 tooth will give you more top end and less low end grunt. We've dropped to a 12 tooth on Son of Weldangrind's XR200R. We want a wheelie machine.
#59 |
For where I am the 13 is just right.
![]() I climbed a stupid steep long hill yesterday that gives Q fits. The Dirt Rat calmly chugged up it. Mostly in second, with a downshift to first at the top. If the motor was broken in, and I was allowed full throttle, it wowuld have done it in second no problem. A better rider wouldd have done it in third! :oops: Since this bike will never see the street, a 50ish MPH top speed is more than enough. If it was an XL, I bet it could be geared for a comfortable 65. As always, it's too bad the China motors are not 6 speeds. That would solve this gearing issue. Or a high low transfer case.
Happy to serve. |
#60 |
Here's the hill. It's much bigger in person.
Happy to serve. |
