#46 | |
![]() I dont think it was brittle steel I think it was simple metal fatigue from the high mileage and poor design.(and probably a loose fitting engine) I wonder when it actually broke, at mile mark? (we'll never know) Since the engine completes the frame it is most definitely a factor in it breaking. |
#47 |
Guest
Posts: n/a
it did hold up until they took out the engine right?
#48 | |
Man... to see the sunrise on Europa, to cruise the dustlanes of Andromeda... flattracking on the rings of Saturn.. burnouts on the moon, FTW! all on a China bike!! In all seriousness, I'd like to see that frame in person... it's a bit worrisome. I don't have a great deal of confidence in Chinese metallurgy as it is. This just reinforces that. A frame should be strong enough to withstand a good deal of abuse (not talking about 30 ft jumps!) without failing like that. |
#49 |
Well from my own personal experience I have snapped the stock engine mounting bolts just riding it lightly on paved roads and some dirt roads.
After replacing the engine mounting bolts I have ridden mine over countless whoops that have pounded the frame without failure. That open frame design is fine as long as it is done correctly but on these bikes they just use the wrong size/type engine bolts and it allows things to move and flex. OH I would very much like to have a good close look at that frame also as well as the engine and engine bolts. The engine wouldnt be a big concern to me if the frame was closed but since the engine acts as part of the frame it is also part of the equation. It is a bit of a concern but I did buy mine to run the woods and the woods it will run. |
#50 | |
My bike has a different exhaust note because its gray.. It's more of a timp then a thump. ![]() What I don't understand is WHY you would spend all kinds of money paying for them to replace engine gaskets and parts when you can get another brand new one for not much more then it cost you to fix that old one. I also noticed your exhaust and parts were rather rusty/dirty. Do you keep you bike in a garage where its protected from the elements? I would strongly suggest this with your new bike, it will look better and last longer that way. The strength of the frame or metal in the frame has nothing to do with taking care of the bike on a regular basis. I don't really think its your fault I could not imagine what you would have had to of done to get such a clean snap like that. It almost looks like someone took a sawzall to it or took it off a massive jump. I am willing to bet if the frame was boxed in this never would have happened. If you did take it off a massive jump you must be a good rider ![]() ![]() If they are giving you a new bike GREAT! We really don't need a commission report on what could have went wrong because the issue is resolved. I am happy for you, that is way more then most dealers would do.
"C is for cookie, it's good enough for me; oh cookie cookie cookie starts with C." |
