Old 05-15-2022, 11:16 PM   #46
TORKER   TORKER is offline
0
There are currently none to be had anywhere. Likely a shortage issue. Who knows when we will get more again.
Thank you sir. Much appreciated. Next question would be: How difficult is it to make one?
And what to start with (another key?, from what?). That is, in case its recommended. I can hold my own with tools and own quite a bit of them, but don't have special equipment.
TORKER.
Old 05-21-2022, 05:34 PM   #47
Does the CRF/XR 100 keys fit our engines?
TORKER.
Old 07-22-2022, 08:26 PM   #48
tigerjacopo   tigerjacopo is offline
news about flywheel keys?! i wrote joe and he told that he s out of stock and he would not ship me anyway (oversea shipping)…
anyone with ideas or other factory ??
Old 10-19-2022, 10:41 AM   #49
ghostdancing   ghostdancing is offline
make your own with a piece of steel, a file and lot of patience?
Old 10-19-2022, 10:47 AM   #50
I have two. I could part with one of them. PM me.
2004 Honda ST 1300
Old 02-21-2023, 10:36 AM   #51
Hawk 250 pnw   Hawk 250 pnw is offline
Any install video and purchase link for this? Thank you
Old Yesterday, 10:20 AM   #52
oouthere   oouthere is offline
Why not just dremel part of the old key, fairly certain that's all the resellers are doing.
Old Yesterday, 10:58 AM   #53
You would have too much play. The 4 degree timing key is machined with an offset.
2004 Honda ST 1300
Old Yesterday, 01:09 PM   #54
Thumper   Thumper is online now
What Jerry sez is definitely true. There can't be any play in the woodruff key. That is, it can't be a loose fit in either the crankshaft OR the rotor.
A timing advance key has a lower section that fits the slot in the drive shaft, and an offset half round upper half that fits in the rotor. Neither side is "ground down".
You can see in the photo, the upper and lower parts are the SAME width. It is just offset. The offset key must fit tightly on the shaft and in the rotor, so you can't just grind off metal to make the offset.
No matter where you go, there you are
