#46 | |
Right now it's an experiment with unknown results. jb
2016 Honda CB500F......2017 Triumph Street Twin 2014 XT 250........ |
#47 |
I think if (when?) I change to a K&N-style pod filter to open up the breathing for the new muffler, I'll remove the whole contraption, run a tube off the crankcase across the motor and off the backside, then put on a small filter on the end of it just to keep any possible junk from being sucked it. That will also let me know how badly it's oozing.
I'm just not a huge fan of running swamp gasses back through what should be a fresh/clean air situation that a possible intake sensor and O2 sensors are sniffing.
#48 |
Operation Bin Bag
The results are in, folks
![]() The bag I used was about 5 - 6 litres ( tested by filling with water) Test 1, Idle (1500rpm), Temp range 27c - 65c = 6 mins to fill bag. Test 2, Idle (1500rpm), Temp range 80c - 85c = 6 mins to fill bag. Result, About 1 litre of blow by gas per minute at idle ![]() I was expecting a little less at the higher temperature. |
#49 |
katflap blinded me with SCIENCE!! ;-)
That's pumping out some good volume. I wonder what it's like at 5k?
#50 |
And it blows up balloons! Is there anything the RX3 can't do?
#51 |
We found something all of our China Bikes couldn't do the other week remember
"Think as you like... but this self proclaimed Professor is always right" - Buckshot ![]() "You never know what someone is hiding beneath their smile..." - NinjaTom - R.I.P. |
#52 |
broke out in laughter...good one
#54 | |
Well as you ask... This gives me the excuse to quote a little more, "Shed Science" ![]() The formula quoted in the article i linked in a previous post is - RPM x ENGINE SIZE (in litres) divided by 2 ---------------------------------------------------------------------------------- 5000 x 0.25 :- 2 = 625 Litres per minute ( volume of air being used by engine) ----------------------------------------------------------------------------------- "The blow-by rate, is a percentage, which expresses how much of this air leaks past the piston and into the crankcase. It can only really be determined through direct measurement but good rule-of-thumb figures are" 0.5% - New engine, after run-in. (0.005) 1% - Design target for breather sizing. (0.01) 2.5% to 3% - Maximum (e.g. for a worn engine, or poor piston ring sealing) (0.025 - 0.03) --------------------------------------------------------------------------- 625 x 0.005 = 3.125 litres per minute -------------------------------------------------------------------------------- So the answer is about 3 litres per minute @ 5000 rpm on a good engine Thats about 3/4 of a gallon of by pass gas every minute. __________________________________________________ _________________________________________ The by pass gas is mainly damp air with a little exhaust gas and fuel. If the blow by gas contains only 0.25 % of fuel, thats still a teaspoon full of fuel vapour being dumped in to the crankcase every minute. Ok i'm done waffling on now , going to shut the shed door ![]() Last edited by katflap; 08-21-2016 at 03:17 AM. |
#55 |
Bin Bag clarification?
Good test, Katflap.
But are those metric, Imperial, or US (inch) minutes? Regarding the cold vs. warm, on one hand, the oil is thicker when cold and should seal the rings better, yet when warm the piston expands. Then again so does the cylinder block. Maybe it's all dependent on tire (tyre) pressure? |
#56 | |
![]() Also, results from a British bin bag and an American garbage bag may differ. ![]() |
#57 |
Well done Kat !
************************************************** *** " Time you enjoy wasting, is not wasted." - John Lennon ![]() “I predict future happiness for Americans, if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.” ― Thomas Jefferson "If you don't know where you're going any road will take you there" ....George Harrison song |
#58 |
When I first saw the bag with liquid i thought, good grief that a lot of condensation.
![]() Good job Kat, they don't call it hydrocarbon for nothing. ![]()
#59 |
Tell me that I'm not the only one dumb enough to try this:
![]() But here is what happened, and I need one of you smart guys to explain why. I attached the balloon to the crankcase vent, and let the engine idle for a minute, then revved the engine a few times. Nothing happened to the balloon except a bit of fluttering. When I turned the engine off, the balloon inflated. ![]() jb
#60 | |
If the engine was cold when you started the test, then after shut down the residual heat of the metal continued to warm the air inside the cases, causing expansion. |
