03-04-2007, 03:20 PM | #46 |
I just put on the "POD" type filter today. Man, That was a pain! But well worth the effort. I have only taken the bike for a short test run but it idles smoother and seems to accelerate a bit better. The bike seems to have more pep.
The reason it was such a pain is on the Sierra, two Philips head screws are right behind the frame. I had to remove a bunch of bolts to drop the battery box a half-inch to get to them. Once the filter sub box was removed I just slipped the pod on. I didn’t make any carb adjustments since the bike has been running rich from the beginning. As soon as I get the pics uploaded I will edit this post and put in the links. http://i172.photobucket.com/albums/w...fla/AirBox.jpg http://i172.photobucket.com/albums/w.../PodFilter.jpg http://i172.photobucket.com/albums/w...la/TopView.jpg If you click the link to the top view you can see that, it is positioned at a slight angle but doesn't interfere with the body panels. |
03-04-2007, 05:11 PM | #47 |
Is that your clutch cable routed below the cam chain tensioner?
2004 KAZUMA CHEETAH 200 2001 Yamaha Big Bear 400 1986 Honda ATC 250ES 1983 Honda ATC 200X 1974 Kawasaki KE100 |
03-04-2007, 07:46 PM | #48 |
Yes, the clutch cable attaches to a bracket at the base of the cylinder then to the top of the transmission case just behind the "QC04" sticker.
Are the Lifans significantly different? |
03-04-2007, 07:51 PM | #49 |
yes...at least on the DB-07A, the cable attaches to the top of the right side crankcase cover [clutch cover]
<div>Steve 2006 Roketa DB-07A/RSX-200E 2008 Roketa 250 Scooter 2019 Brozz 250 |
03-04-2007, 07:56 PM | #50 |
Yes, they are different. everyone that I've seen on the lifans is located on the right side, like hondas. Your engine must be a yamaha design.
03-04-2007, 08:16 PM | #51 |
Yes, my GY-5 is on the right side on the top of the crankcase, it's the old XR design...
03-04-2007, 08:24 PM | #52 |
Oh, yes it is. I thought every one here knew that the Sierra is based on the Yamaha XT 200.
I looked at mdionis's gallery pics, he has a real good shot of the clutch cable attachment. I just never paid any attention to the clutch cables on the Hondas. I never owned one. Just Kawasakis in my past Hey! What ever works right! |
