02-11-2015, 03:13 PM | #46 |
i ordered another clutch lever/perch. i also had to order a new clutch cable. these are the parts that i ordered.
my stock cable was the following length cable42.5inches shell 39.5inches new cable cable 48inches shell 44 inches http://www.ebay.com/itm/400376172625...%3AMEBIDX%3AIT (i dont recommend this lever, its horrible quality) http://www.ebay.com/itm/111539440911...%3AMEBIDX%3AIT i had to get a new clutch cable, because my stock one was only long enough for the type of lever that has no adjustment. all the levers i can find for sale, have an adjuster nut on them. my old cable has 2 inches if cable play, the new cable has 4 inches. so i should have lots of room for adjustments. |
02-11-2015, 09:02 PM | #47 |
I don't think I've ever seen a clutch perch without an adjuster.
03-05-2015, 09:20 PM | #48 |
I haven't updated in a while, because i haven't touched the atv in a while. I've been super busy with vehicle work. I've also been waiting on parts. My clutch cable should be here any day. I'll update with pics when I install it. I'll also be installing my new jetted 30mm mikuni carb!
03-06-2015, 12:08 AM | #49 |
Looking forward to it!
04-30-2015, 05:58 PM | #50 |
Got some good stuff done!!
Installed mikuni 30mm Gutted muffler installed winch wiring! just need to weld on the mounting plate This atv seriously woke up with that new carb jetted to 110main jet and 25 pilot jet. after i gutted the muffler, i get a hesitation under full initial full throttle. any ideas? maybe i need to jet higher. ill try to get some pics and an exhaust sound video up soongl |
04-30-2015, 09:10 PM | #51 |
You might need to jet higher, but first try backing out the pilot mixture screw 1/4 turn, and see if there is any improvement.
04-30-2015, 09:11 PM | #52 |
If you need to go beyond two turns to correct the hesitation, try a 27.5 slow jet.
05-01-2015, 04:13 PM | #53 |
thanks! ill try this and update
06-08-2015, 01:22 PM | #54 |
Turning the out the slow jet helped a little, but i think it needs to come out some more.
i put on some golf cart lights and they are WAY brighter than the tusk bulbs that i installed. i think the problem is the cheap factory housings. Got some cool new tires installed!!! ITP 22 inch. |
06-09-2015, 01:49 AM | #55 |
I've wanted to try a wheel upgrade like that. Please let us know your impressions.
06-15-2015, 09:02 AM | #56 |
I found that a tire upgrade from the crappy V pattern made a huge difference on my 250
I could be wrong......it has been known to happen<div><br /></div><div>core directive 172: No member of the core shall report for duty wearing a ginger toupee</div> |
03-18-2017, 10:53 PM | #57 |
Riding Video
Lots of mods since my last post. This video has footage from my last post on here, and about 2 months ago down in the creek keeping up with the big boys creek riding starts at 14:30
03-18-2017, 11:27 PM | #58 |
Alot of stuff has changed since i was active here, Ill start with the winch! harbor freight 2500lb winch installed. I mounted some brackets behind the grill to the frame. I Used a bar mounted controller instead of the crappy wireless setup that came with the winch.
03-19-2017, 11:33 PM | #60 |
