09-07-2018, 11:18 PM | #46 | |
What electrical system does the hawk run? how exactly wokuld i check, I have a meter. I saw the same cdi but with AC. |
09-08-2018, 08:15 AM | #47 | |
The A.C. adjustable CDI I think you are taking about only adjust timing equally across the entire rpm range. So if you increase the timing at the lower rpm the motor will be harder to start. A programmable cdi is tuned via laptop with a tuning program. You can manually set the time exactly were you want it throughout the entire rpm range. The Hawk run an A.C. system. If you search on here you will find a few people have tried the performance CDI and proved they don't work well on the hawk.
09-08-2018, 10:26 AM | #48 |
What about this a.c. cdi?
https://transmic.net/2017/12/29/ac-cdi-v9/ It is programmable and about the same cost as the dc one you found. I think the hawk would get alot out of good ignition timing in the upper rpm range. I'll keep in mind not to advance too much. |
09-08-2018, 10:27 AM | #49 |
You can even change it using your smart phone wirelessly.
09-08-2018, 11:04 AM | #50 | |
