Old 10-06-2014, 07:02 PM   #541
Wolftrax   Wolftrax is offline
Wolftrax's Avatar
Originally Posted by Mudflap View Post
I'd pick EFI too on a street bike but not on a bike I'd be riding alone in remote areas. You would think EFI systems used on cars would be reliable but I've had two fail over the last several years. The computer went out on my Toyota pickup causing me a lot of grief. No way to diagnose the computer except to eliminate everything else and plug in a new one to see if it works. Also had the fuel injector resistor go out on my Suzuki Swift. There are too many parts that could fail and leave me stuck 50 miles from help.
Like I said before 40,000 miles of trouble free miles!!
Is this remote enough?
Mark
2015 Haosen Hawk 250
2014 CRF250L
2014 CB500X Rally Raid
Old 10-06-2014, 07:08 PM   #542
CSCDude   CSCDude is offline
CSCDude's Avatar
I saw a question about California residents and DMV paperwork.
This blog entry addresses that topic:
http://californiascooterco.com/blog/?p=13443
In short, if you're in California we'll handle the DMV processing, but you'll still have to pay the DMV fees. If you're not in California you'll have to arrange the DMV paperwork in your state.
Joe
www.ExhaustNotes.us
Old 10-06-2014, 08:34 PM   #543
Mudflap   Mudflap is offline
Oregon requires an EPA certificate. Is that provided with the bike?
Old 10-06-2014, 11:09 PM   #544
Any idea what the scanner connector looks like?
The Delphi manual describes it as a 6-pin connector. I'm not sure, but I think this might be the connector? Does it look familiar?
Old 10-07-2014, 01:57 AM   #545
Not to me, but I found a pic of the Delphi scanner on page 61 of the manual. I wonder what the cost of a scanner is.
Old 10-07-2014, 07:04 AM   #546
When Harbor Freight wants $85 for its least expensive, automotive scanner, I'm sure the Delphi scanner is not inexpensive.
http://www.harborfreight.com/can-obd...0693-html.html
AutoZone will scan your car's computer for free. A lot of the Harley Davidson motorcycles employ Delphi EFI systems using the same MT05 ECM. The local Harley Davidson shop might not scan your Zong's computer for free, but I doubt they would charge very much.
Of course, you can do a lot of EFI troubleshooting without a computer.
Old 10-07-2014, 09:06 AM   #547
I started a thread on the Delphi Multec EFI system at the following link.
http://www.chinariders.net/showthrea...980#post173980
Old 10-07-2014, 10:48 AM   #548
There is likely to be a CEL that can be used for troubleshooting, which would allow you to count the blinks and consult a table.
Old 10-07-2014, 01:30 PM   #549
Does the acronym CEL stand for 'check engine light?'
Old 10-07-2014, 01:58 PM   #550
The Delphi webpage for the Multec MT05 contains this information.
Serial Communication feature flexibility: Controller Area Network (CAN) or KW2000
http://delphi.com/shared/pdf/ppd/pwrtrn/mt05.pdf[/QUOTE]
Old 10-07-2014, 02:09 PM   #551
I just found a web source which indicates you can use an OBD2 reader for all late model cars to communicate with the Delphi MT05 ECM. I will do some more research, and post my findings later.
In the meanwhile, here are several links to OBD2 and CAN scanners. You can get one from China for $16.25, delivered.
http://www.nationaltoolwarehouse.com...IuJxoCATfw_wcB
http://www.ebay.com/itm/Autel-MS300-...p2054897.l4275
Apparently, you can also borrow an SERT scanner, and export the data to free graphing software.
If you are interested in more information regarding the Delphi Multec EFI of the RX3, you might enjoy visiting my thread on this topic at the following link.
http://www.chinariders.net/showthread.php?t=14126
Old 10-08-2014, 01:41 AM   #552
Exactly. In the early days of OBDI, it was common to use a paper clip to jump two terminals and make the CEL flash. It would flash a series of short and long flashes, which would translate to a code in the book. The problem was that each system was proprietary, which means that each auto manufacturer had a proprietary connector and unique codes. That all changed with OBDII.
You can still short two terminals on the ALDL (assembly line diagnostic link) port, but OBDII scanners are really cheap these days.
Old 10-08-2014, 01:45 AM   #553
That's good news! The cool thing about OBDII is that the codes are used across all platforms in North America. Aside from a few odd codes that are manufacturer-specific (like a Lincoln headlight sensor), all codes are used with all manufacturers.
Carrying that logic forward, the Delphi MT05 likely stores the same codes as automobiles, which would be easily retrieved and diagnosed.
Old 10-08-2014, 01:58 AM   #554
AleksanderTheGreat   AleksanderTheGreat is offline
AleksanderTheGreat's Avatar
If there's hope for OBD there's hope for something similar to this
just find the pinouts and match em up.
Old 10-08-2014, 02:20 AM   #555
That is so cool! I appreciate how he adapted the connector to OBDII, and connected that to an Unltragauge.
That dude has some cash.
