Old 03-13-2017, 04:28 PM   #526
Ron B   Ron B is offline
Ron B's Avatar
wow!!!! switch is here already! just called them friday at 5:00 my time here in alabama. talk about fast service!
Wingless Hawk, 2016 orange RX3, 97 wide glide,2003 KLR
Old 03-13-2017, 08:13 PM   #527
ElectricCircus   ElectricCircus is offline
ElectricCircus's Avatar
Oh No Rear lower fender broke
Hi guys!
Don´t know if your CSC RX3 bikes have this "rear lower fender", but I´m sharing my experience just in case.
A couple of days ago found this fender loose someway, even when the two bolts where properly torqued.
After removing those bolts found the inner 3/8" pipes, that holds the plastic frame, where broken just after the soldered joints.
Name:  20170310_123554 [90k].jpg
Name:  20170310_123612 [90k].jpg
Name:  20170311_102926 [90k].jpg
Name:  20170311_102956 [90k].jpg
Tomorrow will look for a welding shop to fix this.
Regards,
Juan Carlos.
______________
- ex Honda MB100 (1981)
- ex Honda Nighthawk 250 (1991)
- ex Honda Storm 125 (2009)
- ex Corven Triax 250 Touring (2016) (Zongshen RX3 carb)
Benelli TRK 502 (2018)
Old 03-13-2017, 11:13 PM   #528
Jay In Milpitas's Avatar
Thank you for sharing that, Juan Carlos. The CSC bikes don't have that, but I have seen it on RX3 pictures from other countries.
Old 03-14-2017, 12:26 AM   #529
looks like broken from vibration.
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 03-14-2017, 10:01 AM   #530
Agree. But I´ve roded around 200mi dust/gravel only, of 3500mi total.
______________
Old 03-14-2017, 11:02 AM   #531
Originally Posted by Ron B View Post
yep, just a bad switch. Said they had 1 or 2 do that before. only thing is ill have a seperate key for the ignition now but thats no problem.
Hmmm.... I know we've all read here before about dirt or something in the switch causing the stalling problem. I wonder if you had an exaggerated version of the same problem?
Old 03-14-2017, 02:02 PM   #532
Ron B's Avatar
just replaced it (pulled the left side plates and lifted the tank to get to the plug) . Its just a 2 wire switch, in a bind you could put a toggle switch or twist the wires together if you were out on the road somewhere stuck. theres 2 bolts holding it in from the bottom.....mine was missing one. has 2 now.
Old 03-14-2017, 03:37 PM   #533
Did you spot any hole in the bottom where dirt or grunge could get in? I think I read that here somewhere....
Old 03-15-2017, 06:46 PM   #534
Rear lower fender broke, part 2
Today got the repairings at the welding shop.
I´m not 100% satisfied with the job done ; will see how it performs in time. Probably next time I´ll try welding by myself
Name:  20170315_173752 [90k].jpg
Name:  20170315_173805 [90k].jpg
Name:  20170315_173845 [90k].jpg
Just applied a layer of Paint to avoid rusting:
Name:  20170315_184253 [90k].jpg
And set it back in place :
Name:  20170315_185909 [90k].jpg
Regards,
Juan Carlos.
______________
Old 03-15-2017, 10:32 PM   #535
looks like they were letting the new guy learn how to weld
2016 hawk
kaw h1 400 tripple
Old 03-16-2017, 10:08 PM   #536
Huck369   Huck369 is offline
Huck369's Avatar
Rode mine to work today.....was 16 degrees F on the way in this morning
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 03-17-2017, 11:22 AM   #537
A you got heated gear Huck? Once it gets to 42 or below I wear mine!
2017 BMW F800GS Adventure
Old 03-17-2017, 05:12 PM   #538
Huck369's Avatar
Nope, no heated gear, just the heated grips on the RX3...but my commute is only about 20 minutes
Huck
2013 Honda NC700X
2016 AJP PR4
2022 Templar X 250
AMA Life Member
Old 03-22-2017, 09:50 PM   #539
jbfla   jbfla is offline
I took my orange RX3 to a nearby dealer to see if it could make friends with the green newcomer:
jb
2014 XT 250........
Old 03-23-2017, 10:52 AM   #540
Wow! They have them on the floors now! Have they been out long? What did you think?
